I buttoned up the last few items I had lined up and while doing some work my hinge stop failed
The hinge stop was just a winch line that was CA-ed into a hole on the cage side and run through a hole on the chassis side held in place by a set screw. So one pulled out of the hole and the other side snapped at the set screw. I rounded up another length of winch line this time a known quantity as its a 250 lb line from Locked Up RC, they original was a used length from some winch probably a RC4WD.
The original line on the left (Unknown rating) and the Silver 250 lb line on the right which is a bit thicker.
You can see how frayed it got by the set screw here
It was a bit harder to get the lines in place this time but I was able to CA the ends of the line and let them dry to create something rigid I could work with. I drilled out the original holes on the cage making sure not to go all the way through the bed cover. Then I ran a single line through to each side so that I dont have loose ends to tie up in the middle.
I did a bit of notching to the body and sliders to get the body to clear, I also notched in the inner side of the slider to give the diamond plate some space.
You can also see the hole on the sliders that I'm going to use for storing the body clips when I take them off.
Notch is to the right of the diamond plate.
I also did a bit more belt sanding on the bottom of the cage because after I notched the body and getting it to fully close it then sat too low. I sanded so much off that the channel for the diamond plate on the bottom was so thin I decided to cut it off completely. It served its purpose while the glue for the diamond plate dried though.
I made an adjustment to the sliders in the rear angling them out a millimeter or so. I jammed a scrap of 1mm thick PETG in to hold it where I wanted it then drilled a new hole inwards of the stock mount point and used a nut to secure it.
Rear is on the right side
Charged up a battery and I'll finally be driving it tonight and this weekend :mrgreen:
After all the tweaking I did to angle the sliders up the inner fenders just aren't going to work. I may make my own out of styrene but I'll save that for later.
Oh and a quick weigh in with battery puts it at 5 lb 12.6 oz, not bad.
