Nice work Casey, it's coming along!
Wow, cool 3D-printed solutions...
Can't wait to see the rest of your tricks!
Thanks guys, I've slowed the pace a bit but Its still on the front burner so to speak just simmering at this point.
Nice body mount and brace!"thumbsup"
I really need to get a 3D printer!
I dont regret it, I thought the software would be trouble to learn but theres tons of simple free software and tutorials so it wasn't too bad at all.
Very nice Casey, you continue to amaze me with your design skills!! Keep up the good work. "thumbsup"
Ernie
Thanks I appeaciate that Ernie "thumbsup"
Thanks for all these tips guys. Hope I can contribute at some point.
Am changing from 48P to 32P spur/pinion gearing using standard Associated parts. Hoping Bowhouse makes a replacement combo battery/servo tray similar to the one made for the SCX10 II. I want battery way forward for more extreme climbing angles.
No problem, Post up a build thread it doesn't matter what it is just share "thumbsup"
I worked up a front bumper and I'm still not sold on it. The issue is that the body sits fairly high above the chassis rails so to span up to that as well as down to protect the servo horn its about 55mm which is a really thick bumper! Plus the tires are pretty huge so they occupy all the space on the side of the chassis rail so the bumper can only be a narrow one.
I'm pretty happy with the older style of cow catcher bumper I came up with except for the huge gap between the top portion and the middle. It really needs something to fill that space but I dont want a bumper mount winch.
I'd love to hear any ideas you guys might have but so far I'm considering moving the fairlead up above the middle portion to fill some of that space, a radiator or maybe even a JDM style external oil cooler (
google image search if you're not familiar). I considered a Stinger style bumper but I'm really not a huge fan.
I printed a wedge shaped piece to go between the rock sliders and chassis in order to angle and raise them up a bit to fit where the body is sitting.
I cut some left over pieces of these wedges to use as a washer/guide to force the skid to keep true to the wedge. With the screw going in straight (without the wedge/washer) it tries to straighten out so these wedges are necessary. I also used 2mm Longer screws to make up for the wedge, the odd length being a 22mm for the upper links (3).
![](/forums/proxy.php?image=http%3A%2F%2Fi.imgur.com%2FzZGGf7Hl.jpg&hash=8cd8610fecc77f52fdf8f515391624b9)
Now its sits nicely on the bottom of the body
I also printed up a bunch of license plates on
Acme License maker.com in 2 different scales and a few different styles then laminated them.
A bit of a failure here, I designed a template to hold the lettering straight while putting the license plates together using the sticker sheet for the Sendero, got it all in line nicely but failed to center it. Then I decided to make the plates above ^
EDIT: one other idea to fill the space between the bumper and body is to add a light bar or fog lights, I've got plenty of light buckets and I just ordered some raw LEDs so I can finally start making my own sets.
