I thought it might be nice to start a thread where folks can share their thoughts and experience with the Enduro IFS kit and tuning the suspension.
I just picked up the kit and dont have anything to share as of yet. I have heard that the springs are a lot stiffer than usual.
Optional springs from left to right, softest on left hardest on right. ratings are lb/in
Green .71, White .95, Gray 1.49 (stock), Blue 2.09, yellow 2.47, Black 4.75 (IFS springs)
You can see how they've been mostly going in steps of .5 lb/in between the other options then jumping from 2.25 (yellow) to the 4.75 lb/in IFS spring (black), thats a pretty big jump.
I have a feeling a spring a bit softer than the black might be a good place to start tinkering.
I also though it might be worth mentioning to ensure you use the shock relocation brackets included with the kit, it moves the upper mount point down 10.5mm. This step is skipped in the instructions so make sure you do this. Look at the shock towers on gate 12 to see how these go, I assume it uses a 10-12mm button head screw to mount these, 4 in total.
Recently I've been using thicker shock oil but I'm going to try something thinner for the IFS kit. I'm starting with 45 wt in the rear and 30 wt up front. I'm also going to play around with some different spring rates as I think I have most of the optional springs from Element.
So share your findings and setups let us know what you've done and how it did.
