cmbscx10
My turn!!!!
I have been patiently waiting for my chassis to be built and it has its first rod's bent so here we go. There are still a few tabs and other items i requested form Emeryworx to do but i suspect i'll have the chassis in hand in a few weeks.
I am Sooo looking forward to this build and i have been collecting parts and raiding other rigs in the meantime. I am a slow builder but will try to finish as quickly as i can. Credit to all those that came before me and Yes, I humbly borrowed some ideas from pretty much everyone as you will see. Thanks guys.
I am the type of guy that likes to give my real world experience or lack there of :ror:, opinion, help, ideas and tips & tricks all in order to feel like a kid again. I do not get butt hurt or get offended easily. With that said, I hope to receive some constructive criticism that will help me and others enjoy this hobby that much more. I don't do a lot of build threads so my writing and explanations might be a little out there and hard to understand but i will do the best i can and will take pictures as best as i know how.
**** I will not tolerate Cough Twissted Cough Cough suggesting i change the Trans (I already did that) run different axles (I already did that), stretching the chassis (Don;t have the skills) or putting on things that make no sense on MY build ****
** Sorry, don't have a name picked. Open to suggestions. **
Vehicle Build Specs: EmeryworX RR10 Bomber Chassis #001
Here's the parts list so far as of 3/20/2016:
Electronics:
Mamba Max Pro
BEC - Castle Creations; 10-Amp @7.4v
Tekin ROC412 2300KV **
Hitec HS-8380TH Servo (.14 sec/60 - 486 oz-in @7.4v)
Robitronic Aluminum Horn; 23T
Custom Servo Plate (Custom made by cmbscx10)
RCBros Servo Mounts
Holmes Hobbies Bypass
Receiver - Spektrum SR3100
Radio - Spektrum DX4C
Battery - 3S & 4S (After a Rum&Coke)
** This was in my 15lb 1/6scale so i'll see how it goes and if not i'll get a HH XL Puller Pro BL 540 3500kv
Drive Train-Front Axle:
Axial AR60 Axle **
Beef Tubes
GripFab SS Spool
Axial Heavy Duty Bevel Gear Set 38T/13T
Vanquish Wraith VVD V1-HD 5mm Stubs
Vanquish Wraith Scale Chubs; Silver
Vanquish Wraith Scale Knuckles; Silver
Vanquish Knuckle Bushings
Vanquish Shock/Link Mounts; Grey
SSD Titanium Steering Links for Wraith
MIP C-Drive Spline Center CVD Wraith w/ SS Extender w/6mm Outputs; Front
MIP C-Drive Spline Center CVD Wraith w/ MIP T-Maxx/REVO Long Male Bone Spline MP08136 w/6mm Outputs; Rear
Diff Cover - RC4WD ARB; Orange
Black-n-Tacky
** Later Upgrade = SSD Diamond Front Axle for Wraith; Grey
Drive Train-Rear Axle:
SSD Diamond Centered Axle for Wraith; Grey
SSD Skid for Diamond Axle
Vanquish Shock/Link Mounts; Red (Will D-Ano on 1st teardown)
GripFab ARB Locker
Axial Heavy Duty Bevel Gear Set 43T/13T
Lucas Red-n-Tacky
Transmission Super Shafty Bullet Proof Trans Clone built by cmbscx10:
Skid Plate - Axial; Stock RR10 Bomber
DMG Adapter Plate
VP AX10 Housing
VP Motor Plate & Gear Cover
HR Metal gears
SS 6mm Extended Outputs F/R
SS Top Shaft
Robinson HD Slipper
FE bearings
Pinion Gear - Robinson Racing 12T/32P
Spur Gear - Robinson 56T/32P
MIP X-Duty Rear C-Drive w/6mm Outputs
Lucas Red-n-Tacky
Links:
Upper Front Links - Vanquish Titanium; Wraith
Lower Front Links - Vanquish Titanium; Wraith
Dlux UCfab RR10 Bomber Trailing Arms w/Revo Link Ends
Vanquish Titanium Rear Upper Links w/Revo Link Ends
** Dlux UCfab Wraith Trailing Arms w/Revo Link Ends to change WB
Suspension:
Vanquish Currie Antirock Yeti Sway Bar
Kyosho Velvet Blue 4"(104mm E2E); Front
RC4WD King Dual Spring Shock; (100mm); Front Springless
Kyosho Velvet Blue 4" (104mm E2E); Rear
RC4WD King Dual Spring Shock; (120mm); Rear Springless
Shock Spring - Axial 14x70mm - 2.07 lbs/in - Super Soft (Red); Front
Shock Spring - Axial 14x70mm - 3.29 lbs/in - Yellow (Blue Springs); Rear
Shock Fluid - Losi TLR;40w; Front (96mm)
Shock Fluid -Losi TLR;40w; Rear (96mm)
Shock Fluid - Factory Team; 55w; Rear Springless (120mm)
KBess Mfg Wraith Blue Limiting Straps; Front
KBess Mfg Yeti Orange Limiting Straps; Rear
Wheels/Tires:
Locked Up RC Gear Jammer 2.2 SLW, Snowman Rings, 4-40 Scale Acorn Wheel Studs, Scale Zinc HW; Front/Rear
VP SLW Hex Hubs - .475; Front/Rear
Hex - Axial 12mm Aluminum
Hex Pins - Axial
Pit Bull RB2's; Front/Rear
Foams - Crawler Innovations DDeuce 6.0” Comp Cut Inner /Med Outer; Front/Rear
Lighting:
MEMA Engineering Alien Light Bar - 800 Lumens Alien Light Bar **
Vanquish Products Rigid Industries 1" LED Light Bar Silver; Front
1/10 Baja Designs Squadron Pro LED Lights; Front
Axial AX80103 Rear Light Bezel; Rear
Axial AX80049 LED Lens Set Yellow/Clear; Rear
HeyOK KOH and Brake Light Controller w/LED's; Rear
** I have no way to measure but that is the claim
Scale Accessories:
RC4WD Aluminum Fuel Cell
RC4WD 1/10 Hi-Lift Jack
Screwdriver (Custom made by cmbscx10)
CB Antenna (Custom made by cmbscx10)
Water Bottles strapped with Tamiya/Kyosho 1/12 Hose Clamp Set
ABC Fire Extinguisher (Rattlesnake Toys)
Axial RR10 Bomber Interior (Thanks to 2-Shot for the Keeping an I out)
LED Voltmeter/Speedometer ** Credit to WesleyRoy for idea
NEED TO BUY:
CFM Cans
Front Axle:
Housing - SSD Diamond Axle; Gray
Link Mount / Truss - SSD Diamond Front Axle Upper Link Mount; Gray
[FONT="]VP Lower Links for Dual Shock Set Up ** When Available **
My Parts
[/FONT]<!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if !mso]><object classid="clsid:38481807-CA0E-42D2-BF39-B33AF135CC4D" id=ieooui></object> <style> st1\:*{behavior:url(#ieooui) } </style> <![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]-->
Electronics:
Mamba Max Pro
RCBros Servo Mounts
Axial AR60 Axle **
Beef Tubes
GripFab SS Spool
Black-n-Tacky
GripFab ARB Locker
Lucas Red-n-Tacky
DMG Adapter Plate
VP AX10 Housing
HR Metal gears
SS Top Shaft
Robinson HD Slipper
FE bearings
Lucas Red-n-Tacky
Links:
Suspension:
Wheels/Tires:
Hex Pins - Axial
Lighting:
Scale Accessories:
NEED TO BUY:
CFM Cans
Front Axle:
My Parts
