EmeryworX RR10 Bomber Build by cmbscx10
cmbscx10
Ramona, CA
My turn!!!!
I have been patiently waiting for my chassis to be built and it has its first rod's bent so here we go. There are still a few tabs and other items i requested form Emeryworx to do but i suspect i'll have the chassis in hand in a few weeks.
I am Sooo looking forward to this build and i have been collecting parts and raiding other rigs in the meantime. I am a slow builder but will try to finish as quickly as i can. Credit to all those that came before me and Yes, I humbly borrowed some ideas from pretty much everyone as you will see. Thanks guys.
I am the type of guy that likes to give my real world experience or lack there of :ror:, opinion, help, ideas and tips & tricks all in order to feel like a kid again. I do not get butt hurt or get offended easily. With that said, I hope to receive some constructive criticism that will help me and others enjoy this hobby that much more. I don't do a lot of build threads so my writing and explanations might be a little out there and hard to understand but i will do the best i can and will take pictures as best as i know how.
**** I will not tolerate Cough Twissted Cough Cough suggesting i change the Trans (I already did that) run different axles (I already did that), stretching the chassis (Don;t have the skills) or putting on things that make no sense on MY build ****
** Sorry, don't have a name picked. Open to suggestions. **
Vehicle Build Specs: EmeryworX RR10 Bomber Chassis #001
Here's the parts list so far as of 3/20/2016:
Electronics:
Mamba Max Pro
BEC - Castle Creations; 10-Amp @7.4v
Tekin ROC412 2300KV **
Hitec HS-8380TH Servo (.14 sec/60 - 486 oz-in @7.4v)
Robitronic Aluminum Horn; 23T
Custom Servo Plate (Custom made by cmbscx10)
RCBros Servo Mounts
Holmes Hobbies Bypass
Receiver - Spektrum SR3100
Radio - Spektrum DX4C
Battery - 3S & 4S (After a Rum&Coke)
** This was in my 15lb 1/6scale so i'll see how it goes and if not i'll get a HH XL Puller Pro BL 540 3500kv
Drive Train-Front Axle:
Axial AR60 Axle **
Beef Tubes
GripFab SS Spool
Axial Heavy Duty Bevel Gear Set 38T/13T
Vanquish Wraith VVD V1-HD 5mm Stubs
Vanquish Wraith Scale Chubs; Silver
Vanquish Wraith Scale Knuckles; Silver
Vanquish Knuckle Bushings
Vanquish Shock/Link Mounts; Grey
SSD Titanium Steering Links for Wraith
MIP C-Drive Spline Center CVD Wraith w/ SS Extender w/6mm Outputs; Front
MIP C-Drive Spline Center CVD Wraith w/ MIP T-Maxx/REVO Long Male Bone Spline MP08136 w/6mm Outputs; Rear
Diff Cover - RC4WD ARB; Orange
Black-n-Tacky
** Later Upgrade = SSD Diamond Front Axle for Wraith; Grey
Drive Train-Rear Axle:
SSD Diamond Centered Axle for Wraith; Grey
SSD Skid for Diamond Axle
Vanquish Shock/Link Mounts; Red (Will D-Ano on 1st teardown)
GripFab ARB Locker
Axial Heavy Duty Bevel Gear Set 43T/13T
Lucas Red-n-Tacky
Transmission Super Shafty Bullet Proof Trans Clone built by cmbscx10:
Skid Plate - Axial; Stock RR10 Bomber
DMG Adapter Plate
VP AX10 Housing
VP Motor Plate & Gear Cover
HR Metal gears
SS 6mm Extended Outputs F/R
SS Top Shaft
Robinson HD Slipper
FE bearings
Pinion Gear - Robinson Racing 12T/32P
Spur Gear - Robinson 56T/32P
MIP X-Duty Rear C-Drive w/6mm Outputs
Lucas Red-n-Tacky
Links:
Upper Front Links - Vanquish Titanium; Wraith
Lower Front Links - Vanquish Titanium; Wraith
Dlux UCfab RR10 Bomber Trailing Arms w/Revo Link Ends
Vanquish Titanium Rear Upper Links w/Revo Link Ends
** Dlux UCfab Wraith Trailing Arms w/Revo Link Ends to change WB
Suspension:
Vanquish Currie Antirock Yeti Sway Bar
Kyosho Velvet Blue 4"(104mm E2E); Front
RC4WD King Dual Spring Shock; (100mm); Front Springless
Kyosho Velvet Blue 4" (104mm E2E); Rear
RC4WD King Dual Spring Shock; (120mm); Rear Springless
Shock Spring - Axial 14x70mm - 2.07 lbs/in - Super Soft (Red); Front
Shock Spring - Axial 14x70mm - 3.29 lbs/in - Yellow (Blue Springs); Rear
Shock Fluid - Losi TLR;40w; Front (96mm)
Shock Fluid -Losi TLR;40w; Rear (96mm)
Shock Fluid - Factory Team; 55w; Rear Springless (120mm)
KBess Mfg Wraith Blue Limiting Straps; Front
KBess Mfg Yeti Orange Limiting Straps; Rear
Wheels/Tires:
Locked Up RC Gear Jammer 2.2 SLW, Snowman Rings, 4-40 Scale Acorn Wheel Studs, Scale Zinc HW; Front/Rear
VP SLW Hex Hubs - .475; Front/Rear
Hex - Axial 12mm Aluminum
Hex Pins - Axial
Pit Bull RB2's; Front/Rear
Foams - Crawler Innovations DDeuce 6.0” Comp Cut Inner /Med Outer; Front/Rear
Lighting:
MEMA Engineering Alien Light Bar - 800 Lumens Alien Light Bar **
Vanquish Products Rigid Industries 1" LED Light Bar Silver; Front
1/10 Baja Designs Squadron Pro LED Lights; Front
Axial AX80103 Rear Light Bezel; Rear
Axial AX80049 LED Lens Set Yellow/Clear; Rear
HeyOK KOH and Brake Light Controller w/LED's; Rear
** I have no way to measure but that is the claim
Scale Accessories:
RC4WD Aluminum Fuel Cell
RC4WD 1/10 Hi-Lift Jack
Screwdriver (Custom made by cmbscx10)
CB Antenna (Custom made by cmbscx10)
Water Bottles strapped with Tamiya/Kyosho 1/12 Hose Clamp Set
ABC Fire Extinguisher (Rattlesnake Toys)
Axial RR10 Bomber Interior (Thanks to 2-Shot for the Keeping an I out)
LED Voltmeter/Speedometer ** Credit to WesleyRoy for idea
NEED TO BUY:
CFM Cans
Front Axle:
Housing - SSD Diamond Axle; Gray
Link Mount / Truss - SSD Diamond Front Axle Upper Link Mount; Gray
[FONT=&quot]VP Lower Links for Dual Shock Set Up ** When Available **
My Parts
[/FONT]<!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if !mso]><object classid="clsid:38481807-CA0E-42D2-BF39-B33AF135CC4D" id=ieooui></object> <style> st1\:*{behavior:url(#ieooui) } </style> <![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]-->
Very nice man. Can't wait to see this thing. My only suggestion would be that if you're building something you plan at any time to crawl, don't go with the HH 540 XL. It just gives up too much low speed smoothness. The standard size puller pros still have more than enough torque especially on 3s. All my rigs running the standard size puller pro will still wheely on command and make the slipper clutch sing when bound up.
Thanks Screamer. I hope it turns out as fun as any one of yours. What is that 4 now?:lmao:
My plan is 40/60 Crawl and Go fast. Thanks for the suggestion and experience. I love over powerful go fast 1/8 scale but now may change my mind to what you suggested as i won't be pinned all the time.
Should be coming home to you soon. Just a few more things to do. Looking forward to your bomber thread updates on this EmeryworX chassis!
Looking good Mike, that chassis is Sweet! "thumbsup" Another Bomber thread for me to keep tabs on!
Can't wait. I keep looking at the pics you sent. Thank you again. Got my million PM's this weekend i take it. :lmao:
This is more of a fun pic (See center). I have a few items from SSD and i am very impressed to date with the quality and beefiness. They don't have any stickers for us to show respect and put all over our rigs so maybe they will start adding some to orders for an extra $.25 after they see this.
I truly appreciate that. ALL credit goes to EmeryworX of course. I am just bolting on the best stuff i can afford to compliment the chassis. I was going to buy a RTR when they first came out but i couldn't pass up the opportunity for EmeryworX to build a chassis for me.
I really like that the Bomber is going bizerk with all the different platforms and the awesome RCC vendors making stuff for them. For this one i am trying to stay as original as possible minus the replica chassis of course and WB.
That currie sticker on the SSD is awesome lol. I did see someone who had bought SSD rims and in the picture I saw SSD stickers.
But anyways, that cage with the parts your adding will be a badass rig. Nice work so far.
You got it bud! I agree about this platform, I'm on sensory overload as my wife says. If only the vendors could keep up in production (I missed out on the last run of UCFab trailing arms :evil: but scored a set of Blue Monkeys! :mrgreen:)
Very impressive specs. Can't wait to see how this build turns out.
I'd say thanks but a vast majority came from you so thank you. I'm just trying to put the best stuff I can afford on it and that I know works from my experience and others.
I am super excited to get this chassis in hand and do it justice.
Looking amazing so far, can't wait to see it come together.
The shock weights might be a little on the heavy side but that's something you can tune and change easily after running it a bit
I appreciate the comment and me too.
I've never been very good at setting up suspension but that will change with this one. The weights I stole :oops: from bilinvic and until I have a full run weight they are probably to heavy as mentioned. I really look forward to this part of the build.
I'll be watching this build.
I will be interested to see the final weight of this project (and of the IFS Bombers).
Love the Pits. I was thinking about some Flat Irons, but having matching Pits on my YXL and Bomber would be kind of fun.
I'm having a hard time making up my mind on mods for my RR10. I so much bad ass on this forum I keep changing my mind. I've the Delux front truss in the cart all weekend but can't pull the trigger. So many options!
I prefer a slightly firmer suspension, especially the rear shocks. You would think that crawling would require a soft and mushy suspension, but that's not necessarily the case. Overall sprung weight and truck weight have lots to do with setting up the shocks; I am constantly tuning my shocks trying to achieve perfection.
