Thanks for pointing that out as that makes a YUGE difference in clearance comparison.
Beat me to it. But it is a valid point, 4.19’s vs 3.85’s.
Still is a big improvement
Well the conversion kit is finally available, RPP just put up a listing for it. Its $99 just like the last kit which is nice.
https://www.rpphobby.com/product_p/asc42340.htm
I knew I seen this earlier but it was a glimpse only and totally forgot what I saw by the time I got off work. Thanks for posting!
I kinda want to cave and grab one, but still want the Utron kit.
The licensing is just silly in this case IMO. Other than to increase cost...why?
It's also stupid that it comes assembled. Sure you can disassemble it and ensure it was built correctly, but then you have to worry about the screws being pre-stripped.
I didn't catch that it was pre-assembled. That is dumb and is a waste of time on their part. I thought that the original IFS WAS a kit or maybe I'm wrong.
The Utron uses the IFS2.
My guess for it coming pre-assembled is that they are already doing it for the Utron, so it's probably coming off the same assembly line. Rather than separating the parts and individually packaging them, they're probably just grabbing the whole setup off the line and throwing it in a box while some of them go to finish putting together the Utron.
You’re probably right. That is the only reason I can see as to why it would come pre-assembled.
I guess I’ll treat this like an RTR and rebuild it from the start.
It's a sign my friend, you should be buying kits and only kits. Gotta keep your stuffs away from the monkey mittsGood luck! Every element RTR I’ve owned has been full of stripped screws. Hopefully they have gotten better at not man handling their trucks
