After running the Semi Sport for a while, I came back to the parking lot and grabbed some more dedicated crawling trucks and went back to the technical sections for some more play time. I fixed up the front axle in the Aluminator, swapped in a 1080 and went back at it.
I call it the Aluminator since it's pretty much all aluminum, even the chassis. It flexes like a noodle, but it's a lot lighter than the steel chassis. Based off a V1 SCX10 chassis, I crammed some cheapo Capra axles under it, added brass and OD up front, and am running an ancient set of tires... from what? 2010 ish? That makes them 13 years old, yikes.
It's a spare parts build that has kind of evolved over the years, so I wasn't expecting much. I was wrong.
Best pure crawling truck I own, hands down. This is Mission Impossible I call it, One of the hardest lines I hit, it's the left side of my test rock. Until today, only 1 truck has made it so far. The Aluminator walked right up it, and gave me the finger from the top.
I didn't get many pictures, no point since there's a few above, but the axles held up perfectly and it went everywhere, even lines I don't even try with my more scale rigs. Grip from the tires was amazing, 13 years old and straight up owned the trail. Blown away by this truck.
Subjective scores:
Crawlability - 10. Claws (pun intended) its way up, over and around everything.
Trailability - 4. I do need to work on gearing, with the 3 gear trans and Capra axles, it's somewhat slow. Great for rocks, terrible on the trail. Loud to boot...belt drive on the way to experiment.
Steering - 8. Not terrible by any means, but the Capra axles and wide offset tires meant I gave up a bit of steering
Sexy factor - 6. nothing scale about it, but I love the stance and overall look.
Uniqueability - 7. Mishmash of lots of old and new parts, not much like it.
Total score: 7.0
Next up, the Carbon TRX. I built this around a set of axles... I had some built TRX4 sport axles collecting dust, so I picked up an Injora Carbon TRX chassis and threw it together with what I had laying around. An Ecto body fit the sliders perfectly, just trimmed it along the bottom to match the angle of the chassis. Not quite finished, but good enough for a test run!
First time running an angled skid/bent rear link setup. Pretty impressed, lots of clearance.
Also owned Mission Impossible...2 in one day? Unreal. First time out to boot!
Love this pic...
Fantastic line here, the creek is just low enough to make this possible. Come up the creek bed to the rock on the left, transition across to the next rock, and then climb that big one on the right. Aluminator made it look easy, This truck struggled a bit, but eventually made it.
Not a fan of the Hyrax, but I had them laying around nearly new so I decided to use them - soft foam up front, solid single stage out back. They did very well today, I must have finally knocked the new off them. Not sure if they are staying, but overall they did ok.
Subjective scores:
Crawlability - 10. Just a hair behind the Aluminator, I had to work a bit harder on some of the climbs. Crawls like a boss though.
Trailability - 5. Goes down the trail just fine, kinda boring though. somewhat loud, not 100% sold on that motor mount.
Steering - 8. OD/UD helps a ton, steering was a non-issue.
Sexy factor - 7. Nothing fancy per-se, but love the look and overall stance.
Uniqueability - 5. Injora is on to something, there's quite a few carbon TRX's out there. In fact, I ran into another one on the trail.
Total score: 7.0 - fantastic build, very happy with it. Just a few things to finish up.
