Rear steer lockout: $.50
Modify Tires to get way better grip: $0
Cut Stock foams in half thickness wise: $0
8 oz lead in each fron tire: $10 (self-sticking lead tabs and solder (yes, solder) wrapped around the rim; no lead in the rear, as the rear has a battery pack)
6-32 allthread, 1/4" brakeline, Traxxas old emaxx ball ends: $12 total
12.5" wheelbase
use servo tape under clamps
clamps: $3
25% better articulation
batteries:
from a busted black and decker 16.8 drill (4/5sc Nicd 1000mah, currently taking 1368mah (?!?!): $0
trim body so batteries clear in front
ebay used trx 2075 servo and trx old emaxx Servo Saver: $15 total
i mounted the top link to the inside hole on the top and used a trx ball as a spacer and them mounted the bottom link to the outside holes on the bottom of the knuckles. the result is 50% better steering, and total lockout (the knuckles touch the axle now, eliminating the need for rear steer as well)
no, I WIN for biggest electronics!!"thumbsup":lol::shock:
metal gears in the rear gearbox: $27
having a $176.50 Duratrax CC (Anderson Model "Crawler-X") (that outperforms ALL stock Axials: Priceless8):shock:
![Stick out tongue :-P :-P](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f61b.png)
"thumbsup"
yeah, i was dumb and got the RTR; the stock ESC is TRASH, absolute trash (any kind of blip resets it, and it zeroes out the throttle no matter where it is (one time it did it when i had it at full throttle, leading to it going full speed in reverse (16.8v=5mph , a decent jog)
