Bogncrawl
Hmm. I'll have to buy a spare wheel and try it out
Glad to help post up some pics when your done.This will give my ax10 look wider and don't have to spend a money on new wheels. Thanks good mod.
i scored a set of 1.9 8hole beadlocks thru a trade, thought id apply the scale treatment.
used an RC4wd 1.9 pin hub to use as hole markers. (its a shame the moulds on the front of the rim are 8. not 6)
used my drill press with a hole saw attachment as my mill... lol rough, but it works.
and the final product with the RC4wd 1.9 brake disc hubs mounted.
Those came out great and I think the slightly smaller bolt circle diameter of the RC4WD hubs looks better and is should be stronger than the VP hub setup!
as far as I know the Rc4wd hubs are the same bolt circle size as the VP stuff. the Rc4wd disc hubs fit the Axial 2.2 trail ready rims, as do the VP hubs.
hope that helps.
Im not sure what you have man but they arent 100% identical so in that sense you are correct. Im sure I have a thread on here somewhere with an exact comparison and theyre close enough for me with plastic rims to swap in and out. I only have rc4wd hubs so cant compare direct to Vp but I cant get past the fact that the axial 2.2s fit up with vp hubs and the rc4wd ones also fit the same holes.
Rc4wd 2.2 hubs are way bigger than the 1.9 and the 1.7 are the same pcd as 1.9 but have different thread and hub size.
Hope that helps.
snip/
RC4wd 13 - 20 (difference > 7) average diameter 16.5
VP 14 - 19.5 (difference > 5.5) average diameter 16.75
0.25mm between PCD i reckon i can work with.
/snip
WOW! Just.....WOW! Wish I had a drill press now......Sigh!
