DIY slipper eliminator using parts you already have
kushboss
canada
Hey guys just wanted to make a thread sharing the slipper eliminator i made for my axial wraith all i used was the inner slipper plate i just clamped it to my spur gear and centered it by putting the inner slipper plate through the slipper gears hole after that i drilled a hole when drilling i went through the hole in the slipper gear to ensure it is in the perfect spot after that i screwed and put a nut on the end and i did the same thing 2 more times it works perfect a if you do end up doing it i recommend when drilling the holes use a drill bit that is a tiny amount smaller then the screws your using so you can actually thread the screw in to the hole you made i know this is a very poor explanation but heres some pictures not even sure if this will interest anyone but i love how my wraith works now it has so much more power i know things are more likely to break but thats fine i just am careful if the tire gets jammed in a rock i let off the throttle . the picture of the part at the bottom is the exact piece i used to do this when you buy the wraith you get it so you dont even need to buy any parts to do this mod i highly recommend lock tight on the screws and nut
just incase anyone was wondering im running a 32p 58t spur and a 12t pinion with a 3800kv 1410 castle brushless sensored motor
can you post a couple more pics? This looks like what I am thinking of doing- what size bolts/nuts did you wind up using I'm interested8)
