Current Best of the Best?
MAGNUMB
DA U.P.
Brushless ESC- Rhino AM32: https://www.amazon.com/RhinoESC-AM32-80A-Brushless-Crawler/dp/B0BZ7RDTL2?th=1
Brushed ESC- Carisma ARC-2: ARC-2 Brushed ESC (3s Compatible) & MPG-1 Program Box. This had a slight edge for me over the HW G2
Brushless Motor- Crawlmaster BL v2: CrawlMaster BL Series - Brushless Motors - Motors
Comp Brushed Motor- Team Brood Conflux 3-slot skewed: Conflux 540 TK-4 – teambrood.net
Trail Rig Brushed Motor- Holmes TrailMaster Sport: TrailMaster Series - Brushed Motors - Motors
2n1 Motor/ESC- Hobbywing Fusion Pro: QUICRUN Fusion Pro 10en (2in1 FOC System)
2n1 Motor/ESC for rigs under 5lbs- Hobbywing Pro Mini16 with Adpater plate and Latrax pinion. QUICRUN Fusion Mini16 (2in1 FOC system)
Shocks for comp crawler- DLUX Fab: Shocks/Suspension or Team KnK Boss?? Boss Shocks – Team KNK Hardware
Shocks for Trail Rig- Traxxas GTS: Traxxas TRX-4 GTS Aluminum Long Arm Shocks (Silver) (4) [TRA8160]
Tires for overall trial running- Pro-Line Krawlers: Pro-Line Racing 1/10 BFG Krawler T/A KX Predator Front/Rear 1.9" Crawler Tires (2) | Pro-Line
Tires for overall rock crawling- JConcepts Tusk 4.75: Tusk – Performance 1.9" Scaler Tire (4.75" OD)-3022-02
Tires for snow- VooDoo KLR/m: Voodoo KLR | Team Ottsix Racing
Scale Drive Shafts- Boom Racing BadAss Line: Results - badass drive shafts
Drive Shafts- Ottsix Heros: Hero Driveshafts | Team Ottsix Racing
Grease- Hudy Graphite: HUDY
Comp Servo- No Superior Designs RS800: No Superior Designs RC RS800 V2 Ultra High Torque Brushless Servo (High Voltage) [NSD-RS8V2]
Trail Servo- Amazon Special 35kg: https://www.amazon.com/ZOSKAY-Coreless-Digital-Stainless-arduino/dp/B07SBYZ4G5?th=1
Battery Trail Rig- Helios 3S 3700mah: 3S 3700 mAh 45c Shorty Lipo
Most comp trucks are running behind the axle servo so low profile is better... im not going to give any input on what is best since my luck has been mixed.
AM32 escs....i do like the rhino but when i got to thinking about it, all my servo failures were when running that esc and reefs recommend against them for that reason. Could be a coincidence.
Comp driveshafts its hard to argue against dlux. Don't have to oil them every run either.
Never would have thought that AM32 could cause possible servo issues, good to know
Guess i should clarify...Many of the am32 escs are just reflashed and slightly modified drone escs. Some did not have voltage suppression circuitry built in. Fingers were pointed between different manufacturers on what caused servo failures.
The rhinos i believe were actually built as a surface esc and do have the huge caps built in (80a version anyway).
Im not saying they caused my failures, but all 3 were while i was running that esc. I switched escs on one truck and it has been good. I was too lazy to do my other truck and it has been running an 80a rhino and rs700v2 for over a year. One holmes did die on that truck though.
Holmes indicated it's more of a battery issue than an esc (low mah 4s batteries specifically). It just happens that the comp crowd that commonly uses am32 escs, also uses small 4s packs, and direct power servos.
