Cultus builds a Bomber!
Cultus
Canada
I have wanted a Bomber since they were first released, but, unlike my yeti, i have patiently waited for the kit to come out. Well it arrived earlier this week, and with a nice pile of parts to go on, i am really excited to start this new project.
y4mNKrpsgesv0NaYLUsx93CseRYcRtZUILqeUF59ysyEk9ELzT4oe-5M4NhSiTfwXi1cY2P09olLdW6yfONTBwl2V1Tfh65NfY4ll29zusxpfpGRyP7ylPCF1kHXlcaV0nPznNz5i9BoO7rLyeqr3A6nAF0KDRrSUB7X9_OyN4_J6nF3wQLCr71Y2icnMpBHyWxAJk6Daz8E1Er80aUWajYjw
Axial Racing
AX90053 RR10 Bomber Rock Crawler Kit
AX31183 Hi/Lo Transmission Components Parts Tree
AX31104 Machined Slipper Plate (2)
AX31161 Steel 32P Spur Gear (64)
AX24260 AE-3 Vanguard Brushless ESC
AX31047 Brushless 3150KV Electric Motor
AXI80103 Axial Racing Rear Light Bezel & Radiator Set
AX31431 Aluminum shock spring retainer blue (x2)
Vanquish Products
VPS07940 AR60 Currie F9 Front Axle (Black)
VPS07950 AR60 Currie F9 Rear Axle (Black)
VPS07013 Wraith Scale C-Hub Set (2) (Black)
VPS07003 Wraith Scale Steering Knuckle Set (2) (Black)
VPS07510 Brass Steering Knuckle Bushing (4)
VPS07970 AR60 Axle Servo Mount (Black)
VPS07082 x2 Aluminum 12mm Clamping Wheel Hex (2) (Black)
VPS01043 x2 2.2 SLW Hex Hub Set (2) (475)
VPS07350 Yeti Trailing Arm (2) (Black)
VPS07990 Yeti Motor Cam (Black)
VPS07991 Yeti Motor Plate (Black)
VPS06933 x2 Wraith Aluminum Servo Clamp Set (Black)
VPS07036 x3 KMC Rockstars 2.2" Beadlock Wheels (2) (Blue)
IRC00060 Incision RR10 Bomber 1/4 Stainless Steel Link Set (8)
IRC00001 x2 Incision Spool/Locker
VPS07690 CURRIE ANTIROCK YETI SWAY BAR BLACK ANODIZED
Other parts
BLS1511S Goteck Servo – 2 speed
SSD00041 SSD RC Yeti 2-Speed Transmission Conversion Kit
RRP8712 Robinson Racing Extra Hard Steel .8 Mod Pinion 5mm Bore (12T)
FUTL7604 Futaba R204GF-E High Voltage 2.4GHz S-FHSS 4-Ch Micro Rx
CSE010-0004-00 Castle Creations 10 Amp Adjustable BEC
CWR-1003 CI "Double Deuce 5.5" 2.2 Crawler Foam (2) (Standard/Firm)
PTK-7800 ProTek 4mm Aluminum Long Clamp Lock Servo Horn (Blue)(25T)
TRA2362 Traxxas Shock Rebuild Kit
HH-230100003 Holmes Hobbies TrailMaster HV500 High Torque Brushless Servo
HH-250100008 Holmes Hobbies RX BYPASS ADAPTER
RC4ZE0066 RC4WD 1/10 Baja Designs Squadron Pro LED Lights
DMG Bomber spare tire relocate
DMG Bomber radiator mount
4340-3S1PD x2 SMC Factory Spec 11.1V 4300mAh 40C Lipo
BPCF9SKIDS BP Custom Chassis F9 skid plates
PIT BULL GROWLER AT/Extra 2.2 R/C Scale Tires U4 Edition - ALIEN KOMPOUND (x3)
you got some nice parts there.. why did you go with two stage instead of single stage foams though? from what i've heard the bomber is a heavy rig when build up
Thanks guys. My plan for this rig is to be more of a crawler/trail truck than a U4/racer, i have my Yeti for that. I did go with the firm outer rings on the two stage foams and i am sticking with the kit tires, but who knows, that may all change with time.
Keep the build pics coming! Love the build threads on this forum.
Ordered my bomber kit yesterday!!!"
Got to work on the axles today. Incision lockers, vp clamping hexes, and the gears nicely lubed up with udder butter. Man these things are nice, love the 3rd member design!"thumbsup"
y4mJE6c1zhhVFleWYAF3SP-LjIR-9jtYDan9FmLiMPmzeQLcGKNN84Du1jHLPJd-MAcXW3aaMXQ2lUPKwqk5FQTGG0PpA8eJTTun-LWLo8pAzlD_bqlsk2ZcluqGfBefTCpMCVSRcwQ2C3coQ9vetenWhpavMsq-RWV8VqMnisgyYKPkctrseQXE8X2b39RqKO0U0-KMT0OmJFBVyiOW8kT4g
y4mMODW1bT83qzi3n7e78rR_rA2kfYBlegf9R0L8StCZs5OpHoIgX5I1l_wzneJFWhWgqwmHPdoGgiTLPII6LWVJojUO8NBpmvuZvZKMrqbS_Kavg7PuXZXic3BVDXunSxD0znQpDVWLeCRzDeJkN7zyrSHqLbkIxexfJL6gBoAKRlmnbjH7JpiDonKtnDq3sErabld99b-gcokno3jT4G4tQ
y4m4jG5sdc3mw5O6bskfJBJQd_fAcmuC723o2lQKdX8Ati9XSaH6bwI7KHtyPUgR8nMgxtlZDizkQf-Lh7WObyQPVQqhhFHFWQ6tlmkpV5pfxcBAptx0DxS7fU7nBpB328amgiVQAWeWS9hXrr_RJdTJyUTr862pCun-y5aVIUTa9XsRWQpP89vVO1MWEagFlkvFjUMJxV_M1wkGgTq4Kp6Vw
y4mDz32xtpuI2afSwHBCboAq4rgeNthTZx4hAg4dQzAGBteRvhjqXu8hsvwefOrC6g9g8Bz69n3hYWbqkvSSULM3DdPMgIDzcfLRgG-FoqE02ZtWhKGCZqiVxYSS8IigRAacazuBeKH6xCFNd-ZGf_Pag35KZdbjqPhOz3R94AISsZeUOavv4sFrcfsxuZd5k3N2m4lCY7yOiC6vqpAkVWauQ
y4mRK5Fiv_IwYsmfqcqf4tgS0Recf1XEV4OVHmbK1GzydUtYizp1R1P5Vlg0eQDp2VwF7-qBUCb4nIMv8rFTkj1lmN5t5UZuJpZFnt76OVElBez5aAmMU00UpOoseDRPX6rZgVxoTd8vhnk6PafYjrrIFxQ8tDd6x-ClNI4KsT9gKTvNY5bjrkVqazqxvIXy9P9dLdXtphNjRY5Bdbu7Wb_bQ
y4mZZbAbu71oLiK71iG3FVonLDvhOF8VUXNCw1oDkFeFOCWDS3ASqttUSleVPX9zgvyYzgJy83gb1ySsF9f36WCkMlddj7bQRCYzpkvOm0u2Nk7OlI_8nLTJl3-3RCOuFGKYW3aJQYfM5_5RcDqNXb8LlcJCuErod6e42ixFCcpNH7DRPVUOubJlFMlbBDGorTrOVOcdISnzXkSyvrN6mBMYg
Links installed, not my favorite job, but they look really good. The stainless steel are considerably heavier than aluminum or titanium, but its low weight and they should take a lot more abuse than the stock aluminum links.
y4m0xqgF392JzObmWv2Cjo8cR6mLQc8VcOlufvWzW-xjMhRmh7WP6DdhrH6F22GHaC_LkgEUT1n3ir8vVtDCJEWRj2fqwx7ENlo7joHk-a0FeWdYAuKe3YvbzihIW5hnj_fEkBvU12Ke537G77k-fO6JVYotOI6wWG9qNjJvn74PGO6BB2PrKkrp_2AvUm-l42CVROPzFjsvO-HPJB2Vts0qg
y4mpnlUp3nm_Xzn8pa5Mag-FG7xb9RU58t1Dw9ZklkRKkjhmuumw7GFEluHu3c2DvFayU0ZQLq29ITYtWd7xoKmA0QtIU49EXwc-aMj5csdADL5ueu7dffpO9sxJAKKR2skCtYoRP8OeEwEpIqZWCCP1A1Rbk6PehXDqpSnndOQZWHrz8mNtZnSGSYIKZmqKatRLmOH2VLvwiBS8dTuelUT9A
y4mi_79ntoNclliULIRAb1HWqMQIbHl-ZvVxLqGfCkqmPtxWKd9leGqUvWR_BnAB9qbvdEJptN_cg6a2oj4nkDyeG2pvJf60J5aEr69FlfNMhaNdefpkWRHMitgMUN_vB4OQf5EoZJPjHHK4C0p6jiO1HC1qYCnIsrCwJQ4U-w4PQteUC5ot7qZFZN_vc2T6gD54CIsIRHzpTzsD0_jTq6vwg
Got the tranny put together today. SSD 2 speed installed with the hinged arm parts from AX31183. For anyone wanting to use these parts with the SSD 2 speed, you will need to also pick up a shoulder screw AX31073 to make it work properly. VP motor mount, axial spur and slipper plates and RR hardened pinion also installed. Everything went together beautifully.
y4mTtlQ5bYeHl-eTjtY6yM59W0cDULoYOW1ju1f_6CTaDw9UIVjvf17ovfUEinQvJh8JHI9DH_Imy-PJ24_zKcqTQrOpCDLndqZS01Z_kAqsXsA-2U-ObPo1Z_MltrhpSv34wFk24NyggfgTzzCyfC3nBaaxAnna8uMvyHGqDSU4bvvPwVxDv1FTFL2G6s9FNQkPN63lqhn3r6imWJH-5-Mlw
y4m_BTmxrWFgtBtmghn9qzues9C8WeaTAnkJ1m-jkeFW2ysHq0Xgqln6QuiuYvj50KeF9B_4oAb8Tv8CME_w1N3I4TKTKTE8YuuC3tayjLiKk8soB222vaEvYlHdGgzA_gIrgz1KSGdrXtJgGXW4czBSC8ygtaBhR6l1KJ952m2PLEqp3c4nUmNSFS0VyEJHPcePCmK7jSaBWEf_amFdVE2bQ
y4mK_LHkj5IHR2HnaAN9KxofcmafjvQA7Lj7KRgqg8FYpuCQcQw-7BNsGfAkQL3W62rk7a8mJSLGe0LlAT8g-oaoCjp7CAioTMcnBTptoVdH0Z5m4thi-tXsU8ED8Gsvm-cxgiqBOh1tDVg4LaBz3EToTwDL_0VXsJF9rZFXuylcLsgguYr9F4O05TuOA6z8Fs4qjQ2SWHfsO9Vjq8bRLHrVw
y4mq_hUC4kUI9RY2kVYSN_OwHIFRltqG09UNe4b-4_uEkcPYHc6QcEjEHsTAkPznw_hcw3v_cm3zFFBhFuRUh9y2QTV1yPEptfc8emBNi3LTjayLLMmieLCRcTt4zePirJNBFsIaeW2mKSZAAhzf5s36r_XRCpv2dJXxDF5IbncLy-QreB__Zq7lnp8J0bNezfN5I5G6Eo51v6H-Lie5yqWDw
y4mSdgAYqZlGB0kHo0nzBOj5dtLm_thC_QrWtOs_k9tyISC_07qQjG1yrCg5MF6gEXgonWCy2hdl6HLTi3JPA1SASGi56cb9_jRbJYm2qclpZkQgL4pZMbzgJX5s46Z9jkk64AyMiq45h51ESQqhBligQoaq45FlmCljUG6WNiHg3x_NT-gwETpN1jh3dsxCEuRO6_FqsbBjkRPI8Bqrf4HbA
After mounting it all to the skid plate, i have found that the bomber needs a much shorter link to the servo than the yeti did, so i modified one i had down to about 30mm eye to eye.
y4mRJgtM_bmZK6ze6cskTsKh8qSGDe1Ae3xJEeIW60oYSnbuL2JRIXgxblkI-P5FBsOOOQjLXOFOX9IV3c1MqcdJUIsujoP9KaZo1DBa7I9yBNOoalcQJkLFBinnkfEdYieEzdM8WEvX2dvzItsvrxdDNdt6zoLxguPwHhDmqXPjt8P-srKJLsB3N_6KL3FtsqKOMctMLFYgE7b5aQ6stQBGw
Stock driveshafts and shocks have been built and installed. I used these blue traxxas o-rings in place of the plastic spacers, this has worked well for me in my yeti and dingo shocks. I also replaced all the lower balls with steel and the upper balls with these silicone bushings.
y4moDdyECZIwKx-5Pr6snE-On5VJZ57EbGQsfON6_2KA17eDjWWJxT1rOT64g50iCS955-Y1WeqjtaaEgXU7MwPP24Qj-aZsk9_AbCi_PLKcMVtS_mDE8zc0I6ErqJcxmRIH4C8TS_NWrwKdgOLmokIsGv9ZaAqfrQlJ5EkMUKNwHTcYZ_ZoDlA6Yy6kmsMbPJT0ZgdYVUfPLRyiuIafxDSIw
y4mPH1FDxmrWy0wApfeGqmFyAnlskN6TWpJCMQM_MV0HgE5t_w44deM5P2SEuH20R-1ldvZFKxSME8kN2P2VyTuXElL6Weku6eIHIubqca-VbPGXw-P1iIhOp8MOOemk6nU6r4JW74hkNnAWczPOZ8hL2ua0pv8zuhIFVIhQw9iWBCP73nWakMxDX2SUTJ2mSTDY9ICbRr1Pp6PR8pAIFrJaw
y4m8_JOHplznkeQZxLMTHqJ1rJjBRsceQIhPyBPNCZIwP8KNQKqb6WnlzIAcfr1CT1JiCSplitH7gk8Jdjh1vZRbMoiqGg4qrOFl1v2fBCiFgJYLvdjcxeKIJWwMgGhzaVbuUkrkeAa1ce4x992CEbyY-gB6le6sa9Taei7nMVwzs1L2h9wuJ-dV2wRQIxnrWX8CJ8NUBipXroW7UmQrwCllA
y4mypMY3l3WaRUkLXqfgILa_ws0MqcA39Y1ab5afV1BziC5IydtJUs3aWKNzfDCkh3gOeEyQ7l9i4eaPGbJoLpWYPFOH5r87jSZhQLvnX6pNIjtR7boxPTAN6kTgwIM3nBZw45vtdHCw5f6ezJMw6vos614F6EPOOZcHGBGJZJJDAsa_HTE_ai3C9iuwOWbPapiK8mGFed7aKfE2q228OmPzw
y4mb_E4OWHevYJfZPryfMqWrHBI__KLnQv1J6okqlYbKUm8pOg7SGpuXcfdoHbZsuJ2xxtQKCvLcJ-d6gHkTz6K4XmHmIhcf6zfX8B9ABNxtIAVjMlm6rfjv6R_AmldCQs57C1cWDu5vY95DZRiMQaDhXKmgccDTgn84p6a5pn6oyqKmuDj30iGOPQc2H8HNxxVlEL9KQmryu8aVGhxWTdZ0w
y4mKLrdVfezh8PBJtQw8FQjomtWm8PVuYPnqKqLs-9c-4I0GECqLSqPiyW6eGbweWmpz742o_Yw3zY6NjX8sbPs0KSb2CLhfL5ZT3kINWQ0Cf4OFSZqh7UOEmmbLlp77uNPxpGLt_P5W2HNCmK9l97dfT6Jt7IhIvF2YgD1mFmTsUd_TT-W5DK6kEwi4IlGfCMOzkfbKIdiB4yfqko_iyMltQ
Really nice build so far..... but I wonder why you are using a non-sensored motor and ESC?
Thanks man. I'm using them simply because i have them, and i know they work quite well with the 2 speed. I will eventually put a Mamba Monster X and Holmes motor in"thumbsup"
Well i got the cage put together and bolted on! not fun for the old carpal tunnel syndrome, lol. I was pleased to see that the F9 trusses have the 3rd shock mount position built into them, so i could easily run dual shocks front and rear if i wanted to. The sway bar fits nicely in there on the rear"thumbsup". Up next wheels and tires.
y4m00A4kqhl8GjZrpmDtGZlYLNZDjVKQtIWHKYU8wjsz90pP5P_oaTToJU38VcU8IdNMqGW6f5hTxG-ZpmiuZVuExIJViVY0j-Hgkv2FYd7QvdX2YY2MBAcC6Me-J8gfOj5CAxQZoHoTqiMA7RWx68XeDzPqFilSeQ1yhG-RiNssGJ_P6HrNxJji7kBVItUns33Vfa-ofl7LD90WHGh-H4BwQ
y4mJqRif2tqcmomCfk58G4gjTRqh2-Q7sl2omnMRRkHZioBNOsMBXjGRSAXsnicvv44do0T3sBqGd00kFfDlq4FMmsLZ7g2qm1z9N7oSng_b69qF-4vln214mBomLtZTDJcR57xEERYpg-qEzCoB0P_-QJPgihw81KJ2NjSrzMn_s453XGeqwXjzszcpWiGhzv7ULHH1GdFJj-JTBZGmEv2Ag
y4m-vsvLYWjIv6DB7wtuPD58uYwNaUtlsC27dZfPdzyGVqSDuL2Lznmz1ajRSwrJ8M_Zr3TDEThia7vYyCYC-CFtryfnY8zZLMGEioOzAI2Q4c46PB62hOszrmsgjVqVl7KtPdaV3aYG-J2mToeGfaacMGICHCFunmuTxEomS5XYd8-aBd0aaasq7JUEyJepOPJNAVR3I8otpF4pVuh9rpPgg
y4mAScr0ejgkykbfvlglLeM3ljYemMK4qZgJcoZkVT-31b1aK4BASgM3p3Y00Z2ebIfWqBK9s7B9kkhnO0OTz4K1Els9J3AzZR-W91_oof0dFkCXwBHgKKaIihGk3zc38lsaIgieVk1NBJ7qUY29I5Pogg29ZbPpgYFfM3rjBphc7ZzwVVlxfmhBWVB4lsvRJKbuVN1ArrmJxV3cECUuBduog
Wheels and tires assembled! Man these things are pretty:shock: The foams are a tight fit for these tires but should be perfect once the outer foams are broke in. I drilled out the backside of one of the plastic slw hubs so i could mount the spare to the post on the cage but it is sticking out too far, so i will have to shorten the post. I think i finally have a plan for painting the body so i'll be working on that this week, and the parts should be here this week to get the servo mounted. Hope to have her running by the weekend!
y4mPHfl-hVjKs3efTMEl4YAe6BWkJhF0N_5Kz7_EIxFU-U4eZPY2p2a6dl-wq9TL8Usw7gLOQt8Sv67nOdKQH1CVO3IDM9aBX4zwl576z4TVBcd3xPwSkh7Nl-8OWqghZY6lCC5R7CuLbK2bCNEWZGZAzytcHnyjP_ykD9qg0EpSESw9KtOCXhGdfzM5lf6ZsDlOxEyk46ZHMQMgZE9GmxU_w
y4mrk_alLbdZ9ZduXo9TkqKg4oXhp5s1zcUoZjWvSMJrTiZ2dT9GO72ffQwA5bwaWIPRJr7jrDWa3Opra02Frn-HpbybVsgSZhTf7Xo_T65AY8MpWvjH-SlKWdvvB3q4sAFCIKjszuDokvkeNNsNq9--G4dhR59auFExyho7PHX_TAN05HJambMP6Wzh2Qq4C24pqVY2accHikna68PmHsjvQ
y4mjEs-5qN-XpTyH3af-jvYtJmCW2BevDKhAP7yu_pv2KCpGVOG2Fvot93PSCN_04cxO8GxnHcXfrCe_8RwZSHBHjWkFa3YW2lsuzVy-klaQz0THW1L-SBLldbPrTpi2x_h2003Ek74HscHs7XdfU_HNIJc2A-lqWMCPocvsGuIlNFNDw6RHTGWJ5dyTqOEe3t82PdzOZr6oJdmCJPc15xQPA
y4mFw5A3K2-nLsmYEgGhiDYxDG-QW5LyphXMhwi_OMTWs0YU5oPKIeVGhEON3ImLGiPpI0qPPscfSbqwc-p_RTeZjv73B56r5wiFFT9wdbR-LOd9MWno4D2xtxLZghWyUpEZzY3CQzspqvy8zOgJ_Oi1iMbMullqxp0PEltwxGgiiu7E3EWPFQP0A0pKgc6Aw_32PM3g9RO2XhQ1tkiCfUymQ
Paint is coming out nice! Here are some teaser shots
y4mAo6zJhSgGUyOCmmQ4Mig1yqRIC4wzN2lCNbzscvlbt0A_htndt7IhbLyWSZ9xWT38uaztszos43ijwJR0BrHkVeEQflKgODb6cXNWZbujKKS1sntxOAvNcaQNnaudk1lLf445kNWBcRQknSEpX-r3JQNm6Ge7c5-5p680yMRGt9M9Em356haO-dv6uovFd7Iobcyad9cgg9U4l6qi6Khlw
y4mjVfcS8EVWTfZcaELwXPUbNm11DLudCV67CIo3qnuwStGNxgSurTcrrfQapIAVTi-sQsGM30Pwb45UNA_1nYVeDMrofKrh8C0mJKF-zG0KUSMB3XBtg8ET6hJDI7vU-n43lvbykK0FrEbW7I5MSkRGhvgyr_PXKAgCIPntaRVxMN7t6G8bWDE-ci0AXqrFCsPcg59DXi8sd7NW-pc9Y1T6w
y4mrnELLzL7qU2VnRlxw5InLDfWhnaH44NP4Rxjr684f4-UYNXYsLlkGcL4om7PARZHgzSgvRXQ4km50C6HHs4L-UO01CGneYuE4ODAd2vM77c48yF-od-aKilLuj9OZMlY9I9UZzZZP-XWog4s_1_KA7Ypwbw9erHM6r0VkpF8VCnd52lNX8327B7p_Z37barsA_u6cIahZoJTSYzA4188CA
Interior done and panels are almost done"thumbsup"
y4mchdjKBh7K2kOnqsu6fLID01oZAniKMvncojNpr2-N-GDwWAx4ZGCvxduat7YUuUgIeDDdmTjP9VHr0g6IN9AMIvPX2-ygOpKUcOYG5fWckv8I3YEGKCqZlOSTxgX0WhGVHPF2Citq24nU6TyKpRo2TAi6IDT8AJRkfHx7WGatDlrJShEDYJ3HkTVAphwYCmZC9jSV1ldrYTBK8XjQR6aoA
y4mV4DGuxKKqDye8Wh8vszM_1hcDQ4J39R8GXNK7lLyJU0YamjkeWuxwybne2kpJsk49EtL9zq8lKMRDFYT8kw_zMVE1-eT27ZoC14ER-obO-0dUvyvvU-64_UnGPTsjde08fvmv8XxySMB1MtEXJm4xYpPZvYCOWprPz5xaSBd_5COiHQrWGcmcm0qtXBwY7fUrwymHh9zj1Uwj4JUMg89IA
