CrawlMaster Pro on 4s in my Trx4
Edubb
Columbia
I recently put a TorqueMaster BR-XL in my Trx4 Blazer paired with a CrawlMaster Pro 10turn. Is the CrawlMaster Pro 10turn capable of running on 4s?
It's hard for me to understand why you would want to run 4S in a vehicle that is designed as a slow speed crawler, but then I'm not a basher.
It says 2-3s on his site. My guess is it would probably work but would wear significantly faster dealing with the higher voltage.
I emailed Holmes Hobbies with a similar question and they said all of their motors can handle 4S.
Nothing wrong with a crawler running 4S so long as you compensate a bit by gearing down. The trouble with doing this to a TRX4 is that you can only drop the gearing down a tiny bit from stock (depending on which model)
Awesome man thanks a lot!!
