mikro383
Long story short, got a Scx10 II with Capra drive train, ordered a G speed G shot kit, ordered a Dlux portal transmission, but will probably run the Capra dig transmission for awhile, also have a built 3 gear. Will be on 1.9 wheels, have the 1 step up from stock overdrive portal gears, running the savox servo I got it with. Probably won't ever see a Comp so not trying to fit into a class, Lots of slick rock and very loose dirt so wanting to stay away from an Outrunner, seen the comments about the Copperhead and like the stouter BEC in the Mamba X 1/10 not micro, weight and clearance not really an issue, and also Looking at the Holmes Puller pro stubby in 2200kv or should I go 2700kv and or full size 540 can, I am throttle happy and like big hills but I'm no rock racer and still want good low speed control, mostly 3s batteries but 4s not off the table, what do you guys think?
Sent from my SM-S901U using Tapatalk
