thewildblue77
The spring fix on here looked to be for the DIG end. My main issue is not going into 2nd cleanly...the spring that end is fine, its more to do with the slider...and I suspect the servo saver.
Something I did with the shift slider that may help-- I stuck a thin washer/shim on one screw in between the halves of the housing that come together to form the track for the slider. It makes the track for the slider a tiny bit wider, which might help keep the slider from binding up in the track.
I did this during initial assembly and mine has always shifted well, so I can't say how much of a difference it actually makes. Its free to try though.
I cut up some ali sheet to cover mine...I posted this in my build thread, but I'll also post it here... I spent time thinking about how to protect the shifter slot for the 2-speed transmission.
Do I cover it with lexan, somehow make a rubber boot?
In the end, my head was already fatigued from work and I just thought... 3M Tape.... piece of felt.... it'll work. LOL
Where exactly did you shim the axles. My GOM is fine but my sons has a bit of wheel wobble...
I’m really not sure about the transmission. The dig works well but I can’t really tell the difference between high and low.
