Yea. I'm wanting to try that. It'll go in my money pit eventually.I'm really interested in how those Axial Universals work with the Wraith knuckles. If they work well... I might as well just do that.
Sent from my ONEPLUS A5010 using Tapatalk
BLDS esc uses the same set of MOSFETs(think of MOSFETs as a bunch of tiny switches), regardless of its rotation direction. Therefore, the reverse will not have lower amp tolerance, its just programmed to be not as powerful as forward.Are we talking brushless here? If so, yeah. That’s a problem I had too. Couldn’t use my precious sensored LRP Stockspec 10.5t (the bronze coloured one) So, I just strapped-in a time-able Orion v-brush brushed 19t double motor, set that to 0-degres, coupled with ye olde quicrun1060 and swapped the + and - connections on the motor. Tadaah! Reasonable crawling and plenty speed in 2nd gear to make it rather tippy, despite swaybars.
Don’t use the reverse as a forward. Reverse circuits have lower Amp tolerances, and they will blow when under load!!
Swaybar is really the way to go. I talked about it here somewhere, but I made one using a wire coat hanger.Quite dead here, it seems... I'm taking out my GOM tonight for a drive. It's been quite a while. Swapped in stiffer rear oils, hoping it'll help a bit with how easily the rear twists too much, causing a front tire to lose contact and thus often making climbing impossible given the front weight bias.
I was just wondering if anyone's seen/heard anything about a new front bumper or any else for the cage? I'll need to fix the cage failure at the top at some point. However while that's easy enough since it's not near a joint, the front bumper remains essentially unfixable.
Of course I'll also need to fix the gear shifting at some point, but I've been putting it off what with the lack of driving and given how much work it involves - especially since I normally just use the fast gear anyway, even while crawling.
