jrowles91
Will this fit, no mods? TowerHobbies.com | Duratrax Spur Gear 32P 56T Nitro Evader BX
I'm really sorry guys I know I may be beating the horse here but I'm having trouble deciphering which gears fit the Wraith trans. I'm wanting to switch to 32p and Kimbrough doesn't make a 56t spur that'll fit (that I can find). I want to run 56t so I can still run the cover and space the motor a little further from the trans (running Tekin 13.5). I read that people are modding Traxxas spurs but I'm not comfortable moding the gear. I read that people can use nitro Evader spurs with zero mods (which is prefered) but they seem to be too large to fit the gear cover?
Can anyone shoot me a link or just point me in the right direction here?
Thanks
Traxxas Jato spurs bolt right on.
Dang it! Lol already oredered the Duratrax one. Very good to know though. Thank you for the update
No problem. I run them on my Wraith and AX-10's. The Jato spurs are nice and wide for good gear contact, and they are dirt cheap. 54,56, and 58T.
56t on the Wraith will still fit the gear cover right? What about the 58 if you know?
I am not sure. With 32p gears I never run a gear cover. I think you can but I haven't tried.
Any specific reason of not running the cover?
I'm looking into electronics for a Wraith and I think I'm set on the MMP ESC. However my motor choice is still up in the air.
I want the rig to be more crawler than basher which would suggest I go brushed instead, but I run in a relatively clean environment and I'd like to go brushless for the decreased maintenance. I come from running a 55T on 3s in an scx10 and love the low speed control and am fully aware that I will loose some of that with a brushless setup. That said, which brushless motors are known for their above average crawling ability? I don't need the raw power of todays 4-pole motors, nor am I looking to spend $150 on a motor. How do the Gen2 Redlines compare to the originals that it seems a lot of people are running? I was considering something like a 17.5 or 21.5T. Also, for those with experience with other brands, how do other $80-$100 motors compare to the Tekins? I'm also considering a SC4X 3000kv and just limiting it to 50-75% throttle with some negative expo. I'm interested in smoothness, but also torque at low RPM which aids smooth crawling.
Thanks. I just wanted to make sure they didn't make any significant changes to the Gen2 that would make it a bad candidate for a Wraith over the original Redlines.Limiting a motor to 50-75% is never something I really would suggest. Just a waste of power. I would say go with a 17.5-21.5 Tekin and run with it. I'm not sure about the gen2 differences though. Just grab one and gear down. You'll have nice low speed control.
Looking at basic specs shows that the Gen2 might be more speed/power oriented vs. torque, but maybe they are higher across the board.
There sure seems to be a big gap in power between a 2 pole 540 and a 4 pole or 550 size motor which is why I was thinking of a limiting a SC4X for something inbetween. I've also read it has good low RPM torque for minimal throttle crawling which is what I'm after. I'm certainly not worried about full throttle performance so I guess I'd be "waisting" power no matter what I pick. I'm not looking to shred gears and pop wheelies. Heck, I have a 27T motor that happens to run right between the wattage of a 17.5 and 21.5 Redline so maybe I'll try it out first just to see what I'm working with in the power department and then make a choice from there.
