Castle Creations ESC tip thread(brushed)
lets say esc #1 works properly and esc #2 does not. yep i recalibrated each esc outta the truck. i then soldered #1 to the rear motor. tried that esc in channel 2 on my 4pk. worked great. switched to channel 3 and it still worked great. then i switched to #2 and used channel 2 worked in reverse and not in forward. switched to channel 3 and same problem. both escs make the same lighting. both arm and switch colors when going from neutral to forward to reverse. both speedos are setup identical as i too setup up on, save it then transfer it to mother esc.
i had this problem. dissconnect battery from one esc at a time and calibrate that esc to the radio. after you do it for both you can plug it all back together and run it. for some reason it cannot calibrate throttle, reverse, and neutral when both esc's are plugged in.
this worked for me.
I run 7.2V NiMH so 3S shouldn't be a problem. What voltage does the BEC run? 6.0V like almost everything else? I've never run anything bigger than about 165 inoz so I'm not familiar at all with external BEC's or why I would need one. Never figured I would need one. Looks like I'll do some external BEC researching as soon as I get some time.
I plugged the castle link into my stock Axial ax 10 and it does not recognize it. I tried selecting sidewinder from the drop down menu, but no luck. What selection from the drop down menu should I choose. From all I read it should work with AE2 Esc .I wanted to increase drag brake.
What am I missing?
Can someone shed some light on this, I was going to buy the Castle-Link cause I was under the influence that it would work on the AE2. Is this true?:shock:
Can the Mamba Max Pro operate on brushless OR brushed motors? The side of the box states that it will operate a sensored or sensorless motor. So does sensorless include a brushed motor?
Does the Sidewinder Sv2 run brushed and brushless? The site does not have good info on this for the Sv2. Thanks.
yup, i took my sv2 out of my sc truck running a brushless motor, and put it in my sons crawler running a brushed motor..you just need to change the settings on the esc with the castle link
Hey I'm trying to setup my dual sidewinders not sv2s with my dx3r and a wantamix I'm having trouble getting them to connect I can get one but the other won't I calibrated them to the rx without them hooked to the wantamix first and the both work but right when I hook them to the wantamix one will arm and the other just blink all three lights and the one that arms doesnt make the motor move but it stops on the yellow light and goes to green when the throttle is pressed and red in reverse. I put the settings the same way it shows in earlier pages and changed the firmware to 1.24. If anyone has this setup a picture of the wiring my help me out but I've tried switching the connectors and facing them the other way. Thanks
I believe there were times I had to move the throttle to get the 2nd ESC to arm once calibrated. It's been a while since I ran my Bully.
Once they arm, go through the WantAmix set-up. Take your time, do it once.8)
If yours is the newer one, it should hold settings well. The earlier version was decent, but could drift settings at times.
Are all the settings in each ESC the same? I make a profile (drag brake, brake, throttle curves, reverse type, etc.) save it & then load into the 2nd ESC.
I have a CC SV2, with the 3.4 software, is the older software compatible with the SV2 (and where can you find it now?), or, alternately, is there a way with the newest software to remove the pause after braking to reverse?
I know this is an old thread but does anyone have any idea if I could use a sv1 and a sv2 in an moa together? My thoughts are as long as I put all of the settings the same they should work close enough for me to be able to run them in the same rig. Any help would be great.
You can do a lot of ESC mixing in a MOA, even different brands.
How good/bad it will work has to be tried. Even 2 same ESC's but with different firmware versions can have some quirks.
Basically, try to run the same firmware in your 2 ESC's and use similar settings & see how it goes.
