Chris_The_Battery_Man
you have a cap on the speed control's ?
dan
Nope. AS IS!
dan
Last year I was running a mamba 25 with a brushless outrunner in one of my rigs and I updated to firmware v1.25(I think) and it was nothing but problems reverse was slow and had to double tap to get it to go into reverse, even tho I had it set forward to brake to reverse. Drag brake was non existing. I hooked it back up to the castle link and tried to go back to v1.24 but the problems still existed. I'm not sure if the update did something to the software that couldn't be undone or what. To fix the problem I switched to my spare installed v1.24 only and everything was peachy after that. Sold the other esc to someone to someone to run in a mini T. They had no problems with it in forward only. Has anyone else run into a problem like this?
OK did some crawling but I have an issue. I have everything working EXCEPT reverse.
Any ideas on what to check next?
I know the Mamba micro pro does, I just got one.Do the Sidewinder and Mamba Micros have a drag brake 213% setting or is that only on the 1/10 Sidewinder and Mamba's?
The rig is:
Bully axles, lightened
Fubar Skeeter chassis
Castle Mamba Max (1)
Hitec HS-7955TG steering servo (new since the original CKRC one cracked a case ther first day)
CC BEC
Masher 2000 all terrain tires
Berg rims
Futaba 3PMx (I've had this for a while)
Motors.....not sure as they are covered
I reviewed the CC ECS settings and they match what Chris (the battery guy) showed in his thread.
I have played with a few other items but to no avail.
I ran into a similar issue with my MMP, I would have to double tap reverse or wait at neutral for 2 sec. I updated the castle link software and the firmware for the esc. It now had a Crawler reverse feature with takes away the need for a 2 sec pause, it also had 213% drag brake setting. The Crawler reverse function is new, I'm not sure why my setup worked fine one day and not the crawlerut the Crawler reverse function took care of the issue and I still have awesome drag brake strength.
Going to switch to 2 micro pros (when I receive them) and have a question. When I wire up two esc's do I remove the power wire from the second esc that attaches to the third channel on the receiver? Using a 3PKS spectrum w/sr3500 rec. In the mean time I want to try a BR-XL and Sidewinder together. Do you think these will work together?
Thanks,
Neil
A little Belated sorry. Been out for a while. Have you tried re-calibrating?
Like this...... http://www.castlecreations.com/products/mamba_micro_pro.html ??:roll:I'm having trouble finding full specs on the mamba micro pro... Like motor types and sizes. Anybody have any info?
