Car 61 ~~ The Rock Cop ~~~ with VID !
Yeah, like Peter said, I have zero patience, so it was ran a bunch before it was ever completed. It was black before I decided on the cop theme, and the cab was new for that build.
Bracing the rear like shown shouldn't heat up any other joints enough to be a problem, just clean the new joint sections down to bare metal and go for it!
Something that I noticed was never done, it might be a good idea to replace the trans case with an aluminum one. I mounted it originally in an odd way, and the plastic holes in the stock trans case loosened up all the time and eventually stripped out.
awesome info again, thanks !!!!
any pics of it with the 2.2's ???
i mean it's staying 1.9 for now... but would be cool to see more pics.
smores updates....
yummy !
fixing the windshield cowl in the center... most likely winch hook damage from snapping a winch line along the way...
then it was on to filling the holes from the old roof lights, they were a bit trail beaten and needed new mounts. i opted for a whole new updated light bar, so these holes are obsolete now.
then i got a bit carried away with the DA sander and prepped the rest of the cab for paint. i ended up sanding all the original decals off it, so now it's up to me to update the look. maybe i can get something custom made ???
rock cop wish list:
bruiser/hilux interior ... Dash/ steering wheel
RC4WD tranny
coilover shocks
headlight buckets/lens
next project... the back cab.
"thumbsup"
not much of an update, but here's the cage fully stripped and ready for new paint and maybe the braces as discussed.
now i'm trying to figure out what color to paint the tube work.
original color was dark gray.
"thumbsup"
Either powder coat it whatever color you want, or bomb can it a metallic color so when it chips and scratches off, it won't be so obvious! Just remember, tubework is constantly getting touched up/repainted, so make it easy on yourself, whatever you do.
FANTASTIC !!!!!
update.
ok i was having a hard time trying to braze this stuff together. like i said i had purchased everything to do it and didnt have much luck.
( so i thought )
well turns out that my local welding supply didn't have stay silv flux and they gave me stuff called stay clean. today i bring this stuff to my local airgas and they tell me that my flux is for aluminum.
what the flux ????
so here we go, right shit this time...
first attempt.
cha-ching.
you guys are right, using the right stuff is super easy.
:cry:
Awesome!! See not so hard after all. :mrgreen: Now don't go changing the whole thing because you found out how easy it is. :lmao::lmao:
I don't think its been mentioned here yet, and I was particularly proud of this feature of the rig, those tube doors are functional. Brazing those hinge mounts was a real bitch, too!
