Capra Battery Thread
I've got a pair of these batts on on order from AMain that should be here any day.: https://www.amainhobbies.com/lumenier-3s-lipo-battery-45c-11.1v-1500mah-lum2951/p997406
RPP has some 3S Helios 1500 batteries that look like they'll also fit the bill nicely. Helios has a better reputation and I wanted those but RPP was out of stock on everything I wanted to order. AMain had everything but with the Lumenier batteries instead so I thought I'd give them a try.
I also have the same 4100 mah ProTek LiHv packs mentioned by JSterrett which on paper should fit. I'll let y'all know after I get the truck build started soon.
How u like those hobbystar batts soze? I get emails from rcjuice with those advertised. Thought bout pickn up a couple, but figured id get some input from some users first
Sent from my SM-J327VPP using Tapatalk
*shrug* not much to say other than that they work and fit small battery tray applications. It's the main battery I've been running in my element. Works well for me.
Sent from my LG-H931 using Tapatalk
I've got about a dozen RC Juice Hobbystar batteries and I've only one puff on me after about 2 dozen cycles. The rest have been absolutely perfect. Can't recommend them enough.
I'm currently running some cheap 1600mAh 3S soft packs that I was originally using in my plane. With the battery tray set to fit them snug they are 102mm x 35mm (wide) x 20mm .
Gens Ace Adventure 3600's seem to fit.
I know that typically the zippy and turnigy packs are fairly close in size for a given mah. I see that people are able to squeeze in a 2200mah 3s zippy pack. Could someone confirm that the same size turnigy packs fit? I have a bunch of those and it would be easier to justify another truck purchase if my turnigys fit.
I was pleasantly surprised. I was thinking I'd go somewhere in the 30-40 minute range on those.
I'm going to try and dig up a sintered 11T pinion. I had a hardened 11T pinion and it was really loud. I'm not saying that the mesh was necessarily perfect, but the sintered metal on sintered metal sounds a lot better to me. I like a little wheel speed, but not quite this much.
What is the stock Axial Pinion made of?
