BashNSlash
Observation: My SCX10 ii (from the raw builder's kit) has significantly longer run time vs my TRX-4.
Details:
SCX10 ii - Team Raffee 27t rebuildable brushed motor + Hobbywing 1080 ESC + Traxxas receiver + 20kg servo. Stock everything else.
TRX-4 Defender - Castle slate 2850kv sensored brushless motor + Castle Mamba X ESC + Flysky receiver + 20kg servo. Stock everything else.
Tests: Using a 5000mah 2s Lipo (50c, Gens Ace), I'm getting in excess of 3h of runtime on the SCX10. Using the same battery and following the same trail (going over the same objects), I'm getting at most 1.5h with the TRX-4.
NOTE: My son's TRX-4 Tactical and my wife's TRX-4 sport get similar battery life (slightly better on the Sport, slightly worse on the Tactical).
I would assume the brushless system would last longer (the TRX-4 using the stock traxxas motor/esc lasted only an hour), but is the extra weight of the TRX-4 impacting it that much? The TRX-4 weighs approx. 8 lbs and the SCX10 is around 5lbs.
I'd love to get better run time with my TRX-4 as swapping batteries out in the cold winter isn't very pleasant.
Any insights would be appreciated.
Details:
