chopper 54
I am new to the whole LI PO thing. I just want to know if a Dynamite DYN1421 7.4V 2S 1900mAh Lithium Polymer Battery Pack will work with a Goat Brushless Crawler system. Below at the stats of the battery and ESC. I just want to make sure I dont wreck anything. Thanks
Battery Stats:
[SIZE=-1] Goat Crawler Brushless/Brush ESC Specifications:
Forward, Drag Brake, Reverse
Input Voltage: 4-7 Ni-Cd/Ni-MH cells (1.2V/cell) or 2S Li-Po cells
On-Resistance: 0.0012 ohms* (brushless per phase); 0.0012 ohms* (brushed)
Footprint: 1.18” x 1.54” (30 x 39 mm)
Weight (w/o wires): 1.49 oz. (42.2 g)
Rated & Braking Current: 120 amps* (brushless per phase); 120 amps* (brushed)
Power Wires: 14-Gauge
BEC: 6.0 volt/5.0 amp
Motor Limit: 18.5-turn (brushless); 27-turn stock motor (brushed mode)
Discrete Steps: 512 Forward; 512 Reverse
Battery/Motor Plug: Tamiya (battery); None (motor)
Voltage Cut-off: 6.25 volts (when Li-Poly Cutoff Circuitry is enabled)
[/SIZE]
Battery Stats:
- Size - 72mm x 46mm x 19mm
- Nominal Voltage - 7.4V
- Max Voltage - 8.4V
- Minimum Safe Voltage - 6V
- Current - 1900mAh
- Charge Rate - <2A (1C)
- Discharge Rate - 9.5A (5C)
- Weight - 92.67g
- Connector - HPI Style
- Wire - 20 Gauge
[/SIZE]
