bilinvic
I'll be the first to admit, gearing ratios have me pulling my hair out when I try to figure it out!
A stock AR44 axle ring & pinion is 8T / 30T
A stock BOM axle ring & pinion is 11T / 33T
Can I assume the ratio between these two are the same?
A Hot Racing or Boom Racing AR44 overdrive axle ring & pinion is 8T / 27T
Here is how my brain works...if I add three teeth to the stock AR44 r&p, that equals the BOM ratio....If I add three teeth to the HR/BR OD r&p, I get 11T / 30T, which to me will be overdrive compared to the stock BOM 11T / 33T ratio....am I correct or way out to lunch???
I'm thinking of replacing the BOM stock front axle (the whole assembly) with an Axial front axle with an overdrive gear set.
Some please steer me in the right direction!!!!
