Brake Weight
Portals based on ar44, ar60, or new design?
Why would they do a chassis mounted servo on a pro mod rig? That isn't sthcale!
Im sure that is an option.More clearance and articulation with a CMS yeah?
I like AMS and a 4 link personally.
Maybe they will throw a big surprise in and do rear steer as well :ror:
New rear steer kit to be released with the XR10 cutting brake included.
well if there is a locking rear diff and rear steer then it would be posable to lock the inside tire there just needs to be something for it to hang up on like a lower link or shock so basicly you could just have the tire interfere with something at full lock with the rear diff open and poof cutting break the outer wheel would still be powered or free if using dig while the inner tire if nothing else just has some breaking affect while rubbing a link at full lock#unansweredprayers
#2010
#neverforget
#unansweredprayers
#2010
#neverforget
sounds easy enuff to me
i remeber drooling over the grasshopper when it came out:lmao::lmao::lmao:
Now I feel old
The servo needs to go somewhere. Whether it's on the chassis or axle it still consumes the same volume of space. Not that its needed but a chassis mounted servo limits articulation vs axle mounted and axle mounted doesn't lose power or stroke based on articulation either.
It's a kit. The tire choice is up to you.Digging the ‘smaller’ size and the tire choice is decent.
