Capra’s axles are too wide to my taste. Wish some aftermarket narrow axles coming out soon. Hehehehe
Vanquish already makes them. "thumbsup"
Did you mean the VP F9 Portal axles? Wish I could find some comparison pictures side by side of these two axles. Or White-Trash you could build one demo set for us here. [emoji1][emoji106][emoji106]
Here's another just for fun, the "Compra".
Not talking the driveshafts running through the axle housings, but the front/rear driveshafts running from the transmission, to the axle housings. If you check the part I mentioned, you'll see that.The provided shafts should be good for this rig. MIPs would be better.
Thanks for the info...I didn't know that. Will have to check into it. After I complete the Capra, my (planned, but not-yet-purchased) next crawler will be the Vanquish VS4-10.You might be thinking MIP only specializes in pucks/CVDs from your racing background. However, they also make "center driveshafts" for crawlers.
Most of those servo arms will not work on many of the micro servos out there as or TLR horns use standard 1/10th size output splines. A lot of the micro servos have proprietary sizes.
Also pure coincidence comparing the servo arms as no TLR/Losi parts have been renumbered by Axial... I should know, I created them all ;-)
The only thing we have shared are the 23T/25T servo insert for the Steering servo arm. Other than materials, nothing from Losi/TLR has been used on any Axial vehicles.
I'll add that we are changing the part number system for Axial to match Losi, Vaterra, ECX and TLR with 6 digit numbers but that's going to take some time for all parts to have this new system.
Just want to make that clear.
Hi everyone, building a Capra with HW Axe Crawler 540 2300kv running on 3S with 4.75" tires. The general consensus that I can find on the internet is an 11t pinion. Long time RC'er, noob to crawlers. Building a SCX III for the GF too and intended use is to take on hikes with us and play along the way. Will the Capra with 11t pinion on 3S keep up with walking speed with the build specs posted above ??
Thanks.
Bill S.
My Capra is running a micro x, 1900kv slate motor, 11t pinion and 3s and mine does walking speed jus fine.
