After learning my lessons regarding assembly, motors, gearing and the like on the Bad Idea Express, I'm moving on to my next project, the Gravel Cannon.
Part of this plan involves adding lights to a custom vac-formed body.
Since I'm using the FlySky Tx/Rx controller, I have a ch3 pushbutton and a Ch4 3-position switch right at my thumb.
I'd like to use a proper light controller to get the "Brake lights, reverse lights, turn signals" effect, using Ch4 for the signals, and I have a source for sequenced LEDs to make rotating beacons, just have to fab a housing. I'd like to toggle those on/off with Ch3 button.
Poking around AMain, I see lots of light controllers for 1/10 scale gear, but I have no idea of the dimensions of those control boards.
Has anyone else done their own lighting like this? What controller(s) did you use?
I know the stock V2 RX has a lighting controller hidden inside, but it also deleted Ch2 so I can't run brushless.
