joe.bielski
I've been running my bronco truggy for ever now and really loved it but the lexan body has started to fall apart. So I decided to go with an RC4WD Mojave Cab with a Tamiya Hilux grill. I really wanted a hard body but I still want to keep the rig light.
The base of the truck is an OOOOOOLD TSC X-trail aluminum Chassis with an SCX10 Tranny and Axles.
Tranny:
HR Aluminum Case w/all hardened steel gears and mirrored.
Front Axle:
HD Gears, Grip Fab SS Spool, Beef tubes, Axial High Clearance Knuckles, SSD Pro CHUBS, Axial CVD's.
Rear Axle:
HD Under-Drive Gears, Grip Fab SS Locker, Beef Tubes, STRC Lockouts
Electronics:
Holmes Hobbies Crawlmaster Pro 20T Motor, Castle Sidewinder V3 waterproof ESC, Spektrum S8000 Servo (They are actually waterproof and has 306oz torque), BEC set to 6.0V, 3s 2700mah Battery, Spektrum RX/TX (have switched to a futaba 4PL due to the spectrum glitching).
Wheels and Tires:
Gearhead 1.9 Trail Kings, Pitbull Rock Beasts and C.I. Foams.
RTR Weight: 6Lbs 6oz
Here's a boring shot of the guts...
I had to create a new cage and sliders for the Hilux body. Used the standard 3/16 brake line tubing and 45% Silver solder. Expensive solder but oh so strong!!! I've never had a joint fail using this stuff.
Here I was just test fitting the body onto the chassis with the old cage and stinger still on.
The tube work came together fairly quickly and easily. I wanted to make a new bumper that was wide enough to protect the body and have a wicked approach angle. BUT this means that I don't have space for a winch. I'll have to just use a tow strap in those situations.
Tranny:
Front Axle:
Rear Axle:
Electronics:
Wheels and Tires:
