A Collection of Hint's, Tips, Mods for Venom's Creeper
Fnmag
US
Venom Creeper Hints & Tips
I'm new to the CREEPER and Crawling in general. I thought that having a thread with all the great Hints & Tips you guys have already come up with in one place would make things easier for the newer members.
By no means is this list exhaustive, but just something to get the new CREEPERS a little head start and maybe help some of you “Old Hands” with something you might have missed.
Tips during build
Install Motor prior to battery tray - you will thank me later !!
Several Great tips from "MiniWheeler"
“fubar” lockouts, Custom shock mounts, modified battery tray, adding “anti-squat”
Tranny case with "wings"
Drivetrain
VCD Pins Popping out ?? Here's the fix
Integy HD universal drive shafts for the AX-10 on the creeper!!
Washer/Wire/ShockSpacer Mod to lock Diff
And Another
Rear Steer
Remote Diff Lock
Rear Axle lockouts
Siping Tires for increased side-bite
Axial Lockers
Behind the axle steering (BTA)
Suspension
Droop Suspension setup
More articulation through shock mounting options
Traxxas Shock Modification - GoTo page 10
Battery Tray Removal and shock mounting erector set
Original Erector Set CREEPER
Traxxas Suspension lower Links
More Front Clearance
Creeper to X-Trail Conversion
No pics and NO followup from OP, but it is said to work....
Any further info would be great to have. "thumbsup"​
Here's a little something to add.
Common problem of the VCD pins coming out an causing havoc with wheel binds/broken C-hubs. Seen a thread on this here already but members asked for pictures to help visualize.
All you need is a few inches of 1/2 inch heat shrink tubing
Just pull out the shaft in a way you could slide the tubing over it
Cut the tubing and slide a piece over
then shrink it with a bit of heat.
Thanks for adding Skullbasher. I couldn't find any pics of that mod to help in describing it. Now that we have some, should help plenty of people out
That's why I went through the effort to find threads that might be helpful to me as I was preparing to get mine and build it. I appreciate those that have added to the thread with their ideas and look forward to more people sharing their ideas and tips !
This is very helpful to have all these mods in one place!! Less time searching, more time for modding and crawlin. Thanks to all that have contributed to this.
As far as the CVD pins coming out, why couldnt you just drill and tap them and use a set screw? Even if its only tapped on one side similar to the Revo driveshaft ends. Would that work better if not the best?
That would work also I just used the heat shrink on mine and have had no problems sence.It is a pretty poor desing if you ask me next I will just up grade them and never have to wory about it again.
Love how none of the links lead back to my build. I've done most all those mods one way or the other. Oh well. One of the first ones to mod these and no love. :(
Im assuming you havent tried tapping hardened steel before?8)
