48 pitch 11 tooth pinion gear?
NeoPyro
United States
Hello friends, I want to swap out the stock 14 tooth pinion gear for a 11 tooth pinion gear in my Capra, but try as I might I cannot find one that is 48 pitch. I see that there are plenty of 32 pitch pinion gears available. Can I use a 32 pitch 11 tooth pinion gear in the Capra?
It's 32 pitch? Huh, on page 23 of the online manual it lists AX30569, which is a 48 pitch 14 tooth pinion gear. I'm so confused. Did they switch to 48 pitch gears at some point or vise versa?
This is what I am using
AXI30722
Axial 32P Pinion Gear w/3mm Bore (11T)
Pinion gears aren't that expensive. I'll give a 32 pitch a try and if it doesn't work I'll get the 48 pitch.
Thank you guys for your insight and assistance.
