Here's a quick little update.
I sanded on the body for a bit.
Lowered the rear a bit by removing the lower spring cups.
Those things are over rated anyway. lol.
I'll try to source some shorter springs somewhere...
I sanded some and went for a short crawl. The rig just kinda felt top heavy.
Well, it is a CJ.
So went back to the shop, and while I was sanding, I noticed a set of wheels/tires on the rack. As much as I like those baby TSLs, they just don't work on this setup anymore.
I decided to use these wagons I got in trade with a Trail Stomper.
Someone had weighted the fronts, removed all the foams, and drilled holes in the tire treads. I was going to pitch them...
I also did a bit of homework, and discovered that the baby ESC is LiPo ready.
Looks like the Kemora lost it's LiPo privileges...
That makes me happy for two reasons. LiPos are lighter, so less weight up high where I don't want it. And it's a higher capacity pack. Longer run times plus a 3c charge rate!!!
After another brief crawl, I was happy with the performance.
Started on the roll bar fabrication. I sanded that too.
Instead of welding it, or taking it to get brazed, impatient me decided to solder.
A decision I'll surely regret at the most inopportune time...
But hey, It looks cool for now. Now if I could just find a way to mount it...
sand
