3 speed Scale build.
Pushed the front axle out 1/2", and cut the brand new driveshaft about 3/8" :( .
Just have to move the panhard mount foward, and remount my servo, front bumper ect...
The Bully page has a lot of good things to say about RC4WD XVD's. Their the company that makes the Bullies and you can see how well my rig holds up.
Went for a crawl today two hrs and no breakage, got a bumper on the front, ect. No pics(oops). Next winch mounted/stinger, mips in the front axle, strc straight adapters rear, and a stronger servo/mount.
Its really a great fun. The jeep is looking like a monster beast with huge tires and tough shape.
Thanks man that was the look I was going for, street legal but barely. Somthing you might see on the Ultimate Adventure...
Thankyou for the input Mhuffman I will be ordering some Xvds with my next paycheck.
Threw my 55t motor in the truck and geared up 2teeth on the pinion. Going for more run time without loosing to much wheelspeed.
I have done a little work on this rig the last couple of days, cut and sanded the tires, made some light mount tabs, and started modifying the wiring for the lights.
The light mounts, roof mount
Hood mount,
All buckets on.
Wiring before
Wiring after
Cut and sanded tires
Got the front lights wired in, have to wire the rears yet, tired of tiny wires and not enough length.
With the lights on...
Lights out...
that is sick, what size drill bit did u use to drill out the buckets i need to do the same. i bet that will light up the night"thumbsup"
For the rpm buckets I used a 3/16 drill bit, it is slightly to small but it worked. The other buckets are off the hilux rollbar, with a 5mm hole in them already.
