3 speed Scale build.
Here are the pics.
Still need to mount the battery tray, and move the front bracket back a little.
The battery will be 1.5" lower.
Looking for opinions here
Put a fender together this morning, it is to wide IMO, so should I make it look like stock fenders or go tube fenders?
Here are the pics
i moved all my electronics up sealed my box and just need to get a ballon for my esc
i also made a quik disconnect for my lights need to get some heat shrink still and need to figure out what to do with my on/off switch...i dont think its water proof
I've been following your thread, very cool. It must have been a challenge to get that 3 speed in and working :shock:. I'd go with the tube fenders but that's just my 2 cents worth.
Thanks Traildawg that means alot, as you mentioned getting the trans was the hardest part. I dont have any room for upper links.
Version 2 of fenders, runs the whole length(1 piece)
debating about cutting out the tailgate/back window and mounting my spare tire in the back. Let me know what you guys think.
Rear shot without the spare
Body off shot.
Got the rear corners done, also mounted some light buckets, and put the stock hexes in front(aluminum) and narrow in the rear(6mm).
Got my Mip's built. I had one with 5mm outputs and bought a second , put 6mm outputs on it and that covers my 6mm axle outputs and 5mm trans outputs.
It looks like i am going to have to streach the wheelbase a bit, the Mips are to long to fit in between the trans and axles.
Haha
The rear I will shorten the front I will push the axle out.
What is your guys opinion on Rc4wd's xvd's?
