Wassup guys first time poster here and first hobby grade rc truck. Co-worker of mine had a RGT Rock Cruiser and I really enjoyed driving it around the Little Rock pile we made at work so I was eying up the ECX Barrage. Then I lucked out was able to snag one off Amazon on Prime Day for $68! By then I had also read just about every forum thread on this site and others and very YouTube video on the Barrage and had compiled a parts/to do list for this little truck.
So far I have done:
- Flipped crossmember mounts for battery and electronics
- Removed shock limiters
- Raised body posts and cut off extra (I'm mounted on the 4th hole from top, it's rather high but that's the lowest I could go without having rubbing issues with fender and tire)
- threadlocked the set screw in cvd's (I think that's the right term)
- Trimmed rear driveshaft (roughly 1/2", make sure you smooth edges after cut)
- Moved front bumper one out (I DO NOT RECOMMEND) Made front bumper very flimsy and ended up snapping it off. Mounted front bumper as close as possible, and cut everything off outside of the shackle mounts on both sides. This eliminated the tire rub in the front.
- removed decals
- removed leds (This gave me tons of more run time on the stock battery it was ridiculous)
- rewired to deans to use my 7.4v Airsoft batteries
- The Outboard shock mod isn't a great mod imho because you lose a lot of flex in the front and it's not even close. Even if properly spaced out so the shocks are straight up and down and not at a V, the tire will still hit the Outboarded shock fairly quickly and be prone to tipovers. Perhaps if you are doing mostly trail driving and not rock crawling this will be fine for you but so far I have been doing mostly technical rock crawling and the limited flex up front with oitboarded shocks was unexceptable. I have since inboarded the shocks again and moved the upper mount point to the lowest hole on all 4 shocks. This give me good clearance and the most amount of flex, astronomically more than stock. You will not be able to run a full size Servo however but I have found a low profile high Torque Servo on rcmart.com that I have coming in the mail to test. $69 and not as much Torque as the $25 Power HD LW20MG I was going to use but oh well.
Parts I have ordered and recieved but not installed yet:
- Traxxas Titan 380 Motor (no longer using as I have found and ordered the Axial 380 40t motor out of the yeti Jr)
- Brass 13 and 14t Pinion Gear (No longer using as I found and ordered a hot Racing steel 12t one)
- Traxxas Mini E-Revo front pinion for overdrive mod
- Redcat Aluminum lockers front and rear
Parts ordered and on the way:
- RC4WD Steel Beadlock Wagon 1.9 wheels
- RC4WD Interco Super Swamper 1.9 tires
- RC4WD 80mm Ultimate Scale Internal Spring Shocks
- Punisher Steel 100-130mm Center drive shafts 5mm output
- Hot Racing 12t steel 48p 1/8 pinion gear
- Hot Racing Aluminum 61t spur gear
- Hot Racing Aluminum Center gear set
- Hobbywing 1080 ESC
- Bluebird Low Profile Brushless High Torque Servo
- Axial 380 40t Motor
Parts I still need:
- RC4WD Mojave Front Cab etc
- Custom Flatbed
- Scalerfab Steel front and rear bumpers and rock sliders
- ECX Aluminum Rear Hub Carrier
- other possible upgrade parts from new ECX Doomsday
- aluminum Servo horn
- Looking at Hot Racing Aluminum front knuckles for Losi MRC
Trucks runs great with all stock parts and just DIY free mods. I would love to add some Wheel weights in the stock wheels but don't feel like messing with glue on tires. Posting from my phone at work will try to upload pics later
So far I have done:
- removed decals
Parts I still need:
- Custom Flatbed
