knuckleslammer
Here's my batteries I'm going to order. Kills me to have to order 2 of these ($200 +) but I have to have saddle packs. I'm mental and I don't want a huge block of NimH cells on each side of the axle. I just wish they weren't so expensive.
http://www.maxamps.com/Lipo-2200-111-Saddle.htm
Anyhow, I'm getting this
Cobalt puller 7t Holmes
mamba max
Q1. Will that motor and ESC handle that battery? I think so based on the specs.
Click to enlarge Cells 6-12 NiCad/NiMH or 2-3s LiPo
5v 3 amp BEC output w/7.2v input
Continuous current 100 amps
Resistance 0.0003 ohms
Brake Proportional
Reversible Yes - with lockout
Low Voltage Cut-off - Programmable
Size of ESC overall: 1.9 x 1.3 x 1.2"
2.5 oz (70.9 g)
Q2. Will this goat system handle that battery too?
http://www.amainhobbies.com/product_info.php/products_id/18817
I tend to think not, but want to make sure
Goat Brushless ESC Specifications:
Forward/Reverse: Forward, Drag Brake, Reverse
Input Voltage: 4-7 Ni-Cd/Ni-MH cells (1.2V/cell) or 2S Li-Po cells
On-Resistance: 0.0012 ohms* (brushless per phase); 0.0012 ohms* (brushed)
Footprint: 1.18” x 1.54” (30 x 39 mm)
Weight(w/o wires): 1.49 oz. (42.2 g)
Rated & Braking Current: 120 amps* (brushless per phase); 120 amps* (brushed)
Power Wires: 14-Gauge
BEC: 6.0 volt/5.0 amp
Motor Limit: 18.5-turn (brushless); 27-turn stock motor (brushed mode)
Discrete Steps: 512 Forward; 512 Reverse
Battery/Motor Plug: Tamiya (battery); None (motor)
Voltage Cut-off: 6.25 volts (when Li-Poly Cutoff Circuitry is enabled)
I really want to get 2 of the Manba max and 2 pullers, but I'm trying to save a little coin.
mamba max
Brake Proportional
2.5 oz (70.9 g)
