winnerone23
Get them shocks in the top row of holes!
Get them shocks in the top row of holes!![]()
It was my personal thought to attack the front mount first. I know that I am probably going to get a bunch of flak for my next statement but: When I was Pro Rock Crawling 1.1 myself and the other drivers around me would focus all of our attention to the front of our crawlers, mainly due to the fact that its pretty much the most important half of the rig. Once you get your front suspension, steering, & geometry setup, everything else will fall into place. I always put most of my effort on the front first, then just drag the rear through the gates.
Just my couple pennies. Looking good Glen
move the shocks up to the top row of hols in the chasis
move the rear upper links up one hole on the chasis as well.
by going these to things it will help it form coming over backwards an moving the shocks up in the top holes will lower the cgs
herley dose a fine job of telling you what to do in the setups . I ran mine just like he said to an never had any probs at all. I like the 4pl better than the 4pk myself .
let the rear shocks lay in more than the fronts . this will make the rear softer an it will suck down more on a dig. if you go back an put the setup I was running at natts on there that is the best that chasis ever worked for me
ill try an help you anway I can man it just hard on here an over the phone is all. ill try an point you to everone an every teead I used as well.
I have steped out of the comp thing for a while an all I have is a sporty for now but I will help where I can. I haven't touched my stuff in like 4 mounths now . been thinking of getting out of it all for a min. I just don't have the drive for it now an im not going to just go threw the motions an ack like its fun for me when my hart just ant in it rite now
My main concern now is getting some quirks programed out of my radio and esc's. If I can't control it exactly as I want, setup of the chassis won't matter.
When you look at your radio, and you pull the trigger, do both your throttle lines stop at the 100% mark?
And then when you push the trigger away, does channel two throttle stop at 100%, and channel four throttle sails clean out to almost the end? (120%?)
'Cause that's what my radio's doing and I have yet to find out how to stop it. Just wondered if that was the reason for the touchy reverse issue you seemed to be having.
I found if I pull back on DT4 (turning down ETA), I can get them to both stop at 100% in reverse, but then going forward channel four throttle stops way short of 100%.
Have you messed with the exponential settings on the radio? That could be your touchy throttle issue.
OK, did you reset the throttle curve in the speed control when you programed it? The preset for it shouldn't deliver a punch, I know you talked about a firmware switch, which usually sets everything to default, but if they were used ESCs and someone had a steep throttle curve programed on it, then you reversed direction on the transmitter (rather than swapping polarity with the motor wires) that might be the cause. ?
Thanks to Conflict, I have a 35mm screw for the Two Screw mod.
