10 year Tribute Build
Finally got a chance to pick up new pinions. Should I go with the 13 tooth or the 14 tooth? I'm not sure how these new Holmes 13turn motors are going to react throughout their range. I have a feeling that they are going to be full of torque on the bottom and super fast at top end. My driving style is more focused on smooth instead of "Rip, Tear, and Hope". Since parts for XR are getting difficult to find, I try to avoid pushing the limits and risk breakage. I do have the RC4WD gears, bushing instead of small bearing, and the 2 bolt mod on the rear. I'm thinking the 13 tooth is going to be the best between the two. I like more "low and slow" instead of massive wheel speed. My diffs have a fair amount of slop, so I want to keep the shock of unloading and loading at high speed to a minimum. Anybody experienced with these exciting motors agree or suggest something different?? I'm actually wondering if a 12 tooth would be a better choice based on the motors and how I drive.
Got a couple new batteries for practice time also. Yay!
Sent from my SM-T580 using Tapatalk
Well,,,,, I bolted in the new Holmes motors and plugged in the new electronics. Immediately during bench testing I was met with a obvious problem in the front axle. The transmission was super grindy, rough, and loud. Upon teardown I found a ball from a bearing embedded in the main gear. I haven't even driven this thing for a long time and it sure didn't sound like this the last time I ran it. I have a few extra gears, some new some used and a lightly used spare slider chassis. I could have easily pieced together a good set, but I decided to go with a new set from Hot Racing since they are still available on this planet. I also ordered a new bearing kit from Fast Eddie, so everything will be nice and fresh. My only worry is that I didn't get a new pack of Traxxas bushings for the weak little upper bearing. I'm hoping the bushings I have are still in good condition. Next update will hopefully be a successful rebuild and an initial review of a return to the rocks!
I'm so afraid to drive! and I'm afraid of the road and other drivers! I'm not sure I can handle it. especially when you all lead not according to the rules then I'm afraid I will rasterise perfectly on the road and I don't know how to behave kong spiele
