1/6 Wraith/Nylint TJ Jeep + scale quad
^ I'm going to plan on allowing it to roll either way... ~ options R good ~ 8)
and maybe later... hinge the windshield so it folds down to the hood.
and thanks t mike for taking a look see and making comment "thumbsup"
I call bull shit
I commented and get called a old man
and get the no thanks kiss my ass
when Taco is old probably older than me
and is the true old man winter
I call bull shit
I'll be sure to reference you as "old fart"
instead of "old man" :razz:
I might be older...
but I'm lighter in muh step ;-)
get ready for the
biatch...
cold as I could make it...
likely wouldn't clear up your brain dysfunction.
'cuz 'dem cells are likely already expended !? Lol/jk
thank you for your nonsensical gibberish again
...Frame build...
~ step one ~
1/2" X 1/8" flat bar, mild steel.
220/40 Lincoln 180 mig gets it done.
Welded up the saddle and mounted that to the skid plate
to be sure I got the alignment right :twisted:
IMO... this stage requires the most precision.
as getting the 8 screw holes aligned with the skid...
was a little tricky and was less then perfect...
So the dremel was administered to oblong a hole or two.
Not too far off tho' 8)
That outta the way... the remainder should be a walk in the park ;-)
The front has no interference with the body...
And clears the interior's foot wells perfectly.
Tho' the rear may require that I channel the interior's sub floor
just a little.
I'm currently weighing my options on doing that.
your not done yet
holy crap what are
beaning like me and taking your
time
to finish
I bought this over a year ago on sale at Home Depot
it not set up and never even been plugged in
sits in my shop collecting dust
I had big plans for it
but once I found how expensive it was to rent a bottle
to weld small material
now I'm not sure
I have the Nylint Buggy body. I used the seats in my 1/6 Gladiator build and also the steering wheel. I need do a build like this to make use of the body. Great build you have here!
can't say I'm familiar to that Nylint buggy body...
what is the scale ?
post up a picture if ya have one.
...thanks for viewing and making comment "thumbsup"
and a thanks to all viewers... "thumbsup""thumbsup"
...gives me cause to keep this build thread going.
~ I need an 1/18 scale crawler... so's I can build a 1/6 quad to go with muh TJ ~
( just thinking out loud ) :oops:
looks simple enough...
just wonder what the body shell/panels come off ? scratch built ? hmmm
guess I'll need do some digging :|
Awesome job so far. Very thought out fab work. Really liking where you are heading with the build.
I like the Quad idea for sure. Maybe one of those ECX Temper or the Redcat Volcano or Everest i think it is called for little $$.
^ thanks
Thinking about altering the frame...
and adding some link riser plates
so's I can adjust the upper link position(s) !?
what's the opinion ?
Hey Taco Chips
I got 2 Exceed 1/18 the scale crawlers
the Green Chassis is stock except I shoe horned in 380 brushless motor
and the second one was made by another person on here
and I just never finished them out,
cause you really cant beat on them and the 380 motor is probably over kill
they don't have the a Chassis that look like the quads
but with some aluminum plate you could make a u shaped
chassis, like the ones in the quad pictures
Or make a small AX10 version frame
the Jeep body will work on both chassis
but I like the yellow body better
it gives a monster truck look
Hey Taco
You could make your own chassis and skid plate
and look on here or online and see if you can
find MRC axles and a MRC tranny or Exceed axles and a Exceed tranny
they make aluminum C- hubs and knuckles and lock outs for the MRC axles
they there is no upgraded parts for the Exceed or very limited aluminum parts
Hey Taco Chips
Hey Taco
meh... I likely wouldn't play with it much anyways...
would just look cool towed behind the TJ.
Think I'll get one of them Exeed/maxstone rtr's
I found one for $ 114. shipped...
Tho' maybe I can get one cheaper !?
I might hassle with making a body body for it...
but the rest isn't getting too much attention.
K.I.S.S or forget it.
...is muh "can do" spirit/legacy ;-)
^ thanks
Couldn't hurt, if you have the room there, plus it'll give you a couple different options for suspension tuning. Good idea"thumbsup"
Taco
small world I was also
A Navy Sea Bee an EO which is Equipment Operator
my reserve unit was in Northern Ca, 2 weeks a year went to Port Hueneme
in Southern Cali, for training
I had fun and almost went on active duty
but I decided to stay home and work construction
I worked for the Electricians Union and the Carpenters Union for years
one trade would slow down in the winter, I would switch trades and work inside all winter, then when it picked up in the spring I switch back
and fore a couple times a year
Hey Taco
check this out
here are 2 1/16 scale quads with riders that are pretty cheesy for been a RC
and not very expensive one is $36.00 an the other is $42.00
But I also found this 1/18 scale Quad with no drivers and is pretty bad ass and is die cast not a RC
I like it cause there is no drivers, and you might be able to put a Wild Willy Driver in it
I would buy the third one my self and make a small flat bed for it and make tie downs
and make look scale with loading ramps
or you could make a scale trailer like the one you have for your Tacoma
you could use a SCX10 axle and Tamiya Leaf Springs and 1.9'' wheels and tires
or maybe make it a 1/8 scale trailer or bigger
I know you can find 1/10 quad body's that Lexan if you look hard enough you might find a hard body one
or a golf cart or a John Deere Tractor in 1/10 scale
1/16 and 1/18 your limited
That's why I bought extra's of the Yellow ones
