soze
A little behind on my posting, so I'm just getting caught up with my updates.
Got these recently...
Supershafty servo mount
Supershafty rear upper link riser
I really wanted the black versions, but I didn't want to wait for them to be in stock. In turn, I got these fairly quickly. They actually turned out looking not too bad. If I ever have some free time, I might consider taking a black rattle can at it.
Here's the Supershafty mount compared with the stock mount.
It would appear that the notched side is supposed to face the rear, because they're cut out where the upper link rod-ends are, but then you run into this issue where the servo ears don't mount correctly because of that angled bottom.
Anyway, I turned the servo mount around with the notched bottom facing forward and the flat side of the mounts facing forward. The non-notched side ended up not being an issue as the suspension wouldn't even drop far enough for those upper links to even hit the bottom of the servo mount.
Moving onto the rear link risers, you'll need to source some 3x14mm screws that don't come with the part.
Fits pretty well
All mounted up
I might have to lengthen the upper links to take care of that driveshaft angle.
Fits pretty well
All mounted up
