big specht
That lets you control them independently ?
No the GT5 has a Mixer with 4modes for 4wsThat lets you control them independently ?
I have a tech question related to a recently installed MyTrickRC (TRX4) Bronco light kit. I've got everything wired up correctly but my reverse light function backwards (on with forward throttle). A while back I installed a full HH brushless kit, after removing the reverse turn Titan motor I used the HH ESC to flip the throttle (normal rotation) and get my tires spinning the correct direction. A few months ago I installed the SSD portal delete kit, tires spinning backwards again, use the Traxxas link app (more handy than castle link on my laptop) to flip the throttle again, correct tire rotation. Fast forward to more recently after installing the light kit with my throttle direction theoretically set the same as stock and my reverse lights don't work correctly. So is the light kit directly tied to the throttle input coming from the transmitter (reversed)? If I set the throttle on the transmitter back to normal and re-reverse the throttle on my ESC would that fix my reverse lights?
Okay, that's what I thought. I appreciate the advise. Like I said Traxxas link was easier than plugging into castle link and I got my truck running. I'll just have to bite the bullet and everything back to normal.Yes, set the esc to refers and transmitter to forward. Right now if you set the esc's reverse to 50% it would actually affect your forward speed. Setting the transmitter to reverse throttle is pretty much never a good idea.
Sent from my SM-N950U using Tapatalk
I have one question, why aren't we getting these amazing videos here on RCCrawler?? :lmao:
https://www.facebook.com/HolmesHobb...07645/?__so__=permalink&__rv__=related_videos
So is this motor okay for most light "go fasts"?
Also if we order one can we get a sticker with that lil' tugger logo? that would be awesome!
For the CW 01........
All the specs.
Hang up and Drive
It's mainly a question of how you're going to use it, and gearing.
Gear it conservatively and avoid sustained full-throttle use and it'll be golden...
Since your not going for an ultra light weight I would get the mamba x because it can run up to 6s. Not that I need 6s but I do like 4s.
@Voodoo: You ever get that HW880 in to try out the low-ball 4S setup?
She’s still truckin’...
All of the brushed Puller motors have a squed armature. The lil tugger has a straight armature. Basically not as smooth startup.I would also like to know more about the "Lil Tugger", specifically how it differs from the Puller 400. It looks identical, so I assume there are differences on the inside, or else the specs were copied from the Puller 400 and haven't been updated yet.
