So I just got a 3D printer and so far I've mostly just been collecting designs on Thingiverse so I can print them, I've got the printer dialed in or I should say after assembling it its been almost flawless (Prusa I3 MK3).
Anyway I've learned just enough to start some simple designs in Fusion 360 and the first is a rear sway bar mount with a brake light mount intended for using the (medium sized round) Axial light buckets.
Those light buckets are in this set
https://www.rpphobby.com/product_p/ax80045.htm
I was up till 2:00 am last night tweeking the design so I havent got around to taking any pics of it mounted or anything special.
Heres what I have so far, it mounts to the outside of the chassis rails through the rear crossmember on the K10 (now im wondering if the K5 and other models use this same crossmember or not? anyone?)
Theres a hole to mount the light bucket just above the chassis rails and there a little locating hole to keep the light from twisting around.
I've put the sway bar through hole forward a bit so that the sway bar end links land just in front of the springs for clearance (with the wraith front sway bar in mind)
I designed it so the sway bar mounting points are the same width as the chassis rails so anyone who has done the Wraith front sway bar and modified it to fit the chassis will be able to use this bracket
Wraith front sway bar kit:
https://www.rpphobby.com/product_p/ax30781.htm
I considered beefing up the area around the sway bar hole but I'm not sure how much strain it will be under so I've started off with a 2.5 mm thick area and 40% infill.
I'm hoping this can be useful for other folks too, I'm thinking people will want one without the light mount included so I may do an alternate version. I was also thinking that a version with multiple sway bar mounting holes would be handy for those with more customized rigs.
If anyone has a suggestion for what else to use this bracket for let me know.
Eventually I'll be putting this up on Thingiverse so anyone can print these.
I still need to make the passenger side mount, sadly I could get mirroring to work but I will figure that out next.
I was really pleased to have nailed the dimensions on the first go, but I did go back and revise it 4 times, I thinned it out and add a countersunk hole for the light mount hole.
Once I have the other side done I was hoping to send these off to some folks for testing.
