Ok. So its said to tune your kv to your desired wheel speed. I tune for maximum runtime; with 4p brushless there is wheel speed. My problem that i'm having is that i have the smallest pinion and the only spur for my particular RC. I get abot 7mins of runtime on a quality 2s 5000mah pack. I know there are "slightly" higher mah packs that will fit my RC, but from experience i know that it will only add about 2 or 3mins of extra runtime...
The motor is a 4p 3500kv gearing is 47/12 it is a 4x4 sc and there isn't a battery extension made for it. It weighs stock 5.5lbs.
My motor temps after a full pack are about 135-140* mid-day and about 85-93* for the esc...
Is the only option go with 2 super shorties in parallel? I can't remember the mah ratings of the last ones i saw...but i think it was around 4000mah.
Also will Lowering the C-rating increase run time; as it's not pushing all the amps/capacity out of the pack? The C-rating of my pack is 65c 120c burst...
I'm going to test my overkill motor theory...i have a 2150kv 6s capable 70mm 4p motor that should be arriving any day now. I don't plan on running it on 6s but with the gearing i was running a brushed 21t on and same cell battery should yeild great results...At least thats my hypothesis.
T.I.A.
Sent from my LGAS375 using Tapatalk
T.I.A.
