GT3B Hack Question and Answer Thread
Can the gt3c flash kit be used on the gt3b radio? I've just ordered a gt3c radio and hack kit but also have a gt3b that I will flash as well if it's possible.
Sent from my SM-G900V using Tapatalk
Is there anything that can be done to improve the trigger on the 3b? I slipped over holding mine and bashed the bottom of the controller and now it doesn't auto centre perfectly and sometimes I find my car creeping forwards. Moving the trigger back a tiny bit stops it. Also I would like to do the bearing mod to the wheel.
Sent from my SM-G930F using Tapatalk
Depends what is preventing it from centering correctly....I would suggest closely inspecting all the mechanical parts for abnormalities
So there is no bearing mod or anything that I can do while I'm in there checking it? Also are the parts available for these?
You can only add a bearing to the steering wheel.
Some parts can be found....I have a good collection of parts as well.
I just got my gt3b in and when I try to update the firmware it give me an error. I can connect it to the board and start the update and everything, and after about 5sec it says the program has stopped responding and automatically closes. any ideas?
I hacked my gt3c with your kit but have a question. I have several 3 ch receivers but need another input for lights. Is it possible to setup the 4th input on the receiver as a simple on off input for lights (think it's labeled battery) I am using the 3rd ch for front and rear light bars and rock lights but would like to add a winch. The only other option I see is to just simply buy the 6ch receivers even though I'm only gonna need 4 max on any of my vehicles.
You'll need the 6ch rx. You'll keep finding ways to add more stuff. Last month one my customers from 3 years ago messaged me asking if there was a way to get more that 8 channels.
Another option will be adding your lights to a manual switch on your crawler. Heyok also sells remote switches that uses a keyfob.
Or, I'll have these for sale in February or March
Sub Atomic Multi-Toggler
Thanks. I guess I could always run the lights straight off the battery with that cheapie RC4wd inline switch and then forgo the rx all together.
I bought a "stock" GT3B from a friend and am wanting to upgrade it so I can add lights, winch, dig, etc. to my SCX project. Would there be a way that I could send you my radio and have the mods done and then have you send it back? I know you sell the firm ware and such, but I don't trust myself to be able to do it right w/o messing things up.
Sent from my LG-LS997 using Tapatalk
I'm sorry. I don't modify customer supplied radios. I've had issues where people send me a broken radio then blame it on me.
Anyone know what could cause my crawler to loose reverse throttle channel 2? i took the rig apart while back, not sure if i messed somthing up on the radio or not. i have steering, forward but no reverse. its a hacked GT3B Castle Sidewinder 3.
Thanks.
Thanks.
Not sure if this is good but i played with the Channel 2 D/R and Trim settings.
Currently i have both fwd and reverse with the following settings. motor is not in the truck yet but seems like l have a little more forward than reverse. i can at least drive it today.
D/R 75%
Trim F99
Does that setting sound right for a crawler?
D/R 75%
Trim F99
Have you tried calibrating your esc?
https://youtu.be/cwnnw2ZH06w
Envoyé de mon iPad en utilisant Tapatalk
