Synister_Intent
Any ETA when the store will be stocked with these again?
There are only 3 channel, 6 channel, and, 8 channel receivers that are compatible with this radio. Any of the available 6 channel receivers listed on the first page should work the sameHey guys, what's the best 4 ch reciever to use for a hacked gt3b?
I've got a rig I'm running rear steer and dig on and need the 4th channel......
Do I just buy my the 4ch ones off ebay?
Sent from my SM-G920I using Tapatalk
I'm building a vehicle that will have the doors open and shut via my hacked GT3B and a 6 channel receiver with individual servos on channels 3 and 4.
Is there a way to program these as one touch rather than having to hold the button down? Meaning one click fully opens one door, another click of the same button fully shuts.
I've followed the instructions and was able to hook up a winch (on another vehicle) fine but honestly I get lost when trying to program it on my own.
Thanks!
Amazing...thanks for sharing this vid...very detailed
G'day long time reader, first time poster,
I got my GT3C hack kit from overkill, I have managed to set it up and flash the configuration, and all the functions seem available as per the instructions.
I am planning/trying to set up
CH1 "steering"
CH2 "throttle"
CH3 "CH3 button" to shift a 2 speed trans so switch between -100 and 100 on push
CH4 "CH3 Trim" to run a winch in and out as a 3 position switch.
I am pretty sure I have found the instructions to do all of these things with out issue, the problem I am having is that I seem to be able to set the number of channels to be 6 ( as I have a 6 channel receiver). Then when I scroll to set the channel for a function key I only get CH3 as an option. All the instructions say select CHx (3,4,5,6 etc) I don't seem to get this option just CH3 then DIG 4WS etc. Thoughts??
When using the standard setting on "CH3 button" the display tells me I am going from -100 to 100 when pressed but I cant get the servo to move.??
I have tried reflashing the card but am getting the same result. I couldn't find either of these issues in the thread so far. Thanks in advance for your response
Cheers
Ross
Standard menu:
- Model number of channels and Model reset
> choose menu NAME and press ENTER-long
> menu NAME will blink
> choose "C" for number of model channels or "r" for model reset
- reset will show NO/YES
make sure the firmware file you are loading in has the .s19 extension
Thanks for detailed question, I do appreciate it.
To add more channels to your model go to the
long-ETER NAME menu,
Scroll to C, press enter
Scroll to 6, Press and hold enter
Press back/end afew times.
This can be found in this manual
http://overkillrc.com/GT3X-Firmware/0-6-1/MANUAL-0.6.1.txt
And here's the specific lines
Code:Standard menu: ============== - - - - - - - Model number of channels and Model reset > choose menu NAME and press ENTER-long > menu NAME will blink > choose "C" for number of model channels or "r" for model reset - reset will show NO/YES
For your current channel 3 issues. Have you checked to make sure the servo works? Also, are you sure you chose "C" as the button? ("3" is the channel 3 trim)
Thanks Losikid,
My bad I was setting something else as C 6 under the main menu, misread the important bit "NAME". So once I set it from there all the channels showed up, all good.
CH3 switch issue - Servo was in fact toasted- worked last time I had it going go figure. Works just fine with different servo.
Getting the winch controller working on Ch4 just required tuning the trim down to about 70% until the ESC responded and self calibrated, now it is perfect. Winch in and out on CH3 Trim switch.
Thanks for your help am really looking forward to using this in anger, will probably even look at running a lights on and off as well on Ch 5.
Thanks
Ross
