TomFrajer
So I got Axial Yeti RTR and have some plans with it. I will share my upgrades and experience here. This is my first RC car
Here is website for my project: http://yetibuild.com/
Here is how it looks now:
Parts that are already installed in my car:
Team Ottsix Voodoo U4 (blue)
Crawler Innovations Deuce's Wild Single Stage Closed Cell (standard)
MIP X-Duty Rear C-Drive Kit For Axial Yeti #14390
Vanquish Aluminum Front Shock Tower Black Anodized #VPS07790
Vanquish Aluminum Double Sheer Steering Rack Kit #VPS07230
Vanquish Aluminum Front Shock Adjuster Black #VPS07770
Vanquish Front Skid Plate Black #VPS07890
Vanquish Titanium Front Link Kit #VPS07200
Vanquish Titanium Rear Upper Suspension Link Kit #VPS07201
AX31169 - Axial Machined Body Post Mount (Hard Anodized)
AX31166 - Axial Machined Shock Mount Plates (Hard Anodized) (2 pcs)
ProLine PowerStroke XT Shocks (5” Length) - 6275-00
ProLine Power Stroke Shocks - 6063-01
Vanquish Yeti Motor Cam Black Anodized
Vanquish Yeti Motor Plate Black Anodized
RRP1564 - Robinson Racing Gen 3 Slipper Unit for Axial Yeti - 64T Black Steel Spur
NOVAK 5mm 32-Pitch Steel Pinion Gear 3-Pack (15T/16T/17T)
OMF 2.2 Wheel Clamp Ring
OMF 2.2 Front Ring Clear Anodized
OMF 2.2 NXG1 Rear Ring Clear Anodized
OMF 2.2 Original Beadlock Clear Anodized
Scale Wheel Screw Kit
SLW Hub Screw Kit
Vanquish Aluminum SLW 475 Wheel Hubs Silver #VPS01043
Vanquish Aluminum SLW 850 Wheel Hubs Silver #VPS01627
Vanquish Aluminum Bell Crank Black #VPS07810
Vanquish Aluminum Steering Rack Black #VPS07231
Holmes Hobbies Puller PRO BL 540 XL 3500 KV (Waterproofed)
Mamba Monster X
Holmes Hobbies HV500 SERVO
Vanquish Centered Pumpkin Rear Currie Axle Black #VPS07400
Vanquish Incision VDI #IRC00021
Axial Yeti / EXO Steering Knuckles Black Anodized
Yeti Front Caster Blocks Black Anodized
RPM Front A arms for Axial EXO Terra Buggy #70472
GPM Aluminum Anti Roll Bar Set Green For Axial Yeti #YT311FL-G
GPM Steel #45 Front Wheel Joint 1 Pair Set For Axial Yeti #YT039FS
Boom Racing Aluminum Rear 4 Link Mounts - 1 Pair Black
Boom Racing Aluminum Rear Lower Links - 1 Pair Black
Boom Racing Performance Combo Package D With Tool Box (Rear Sway Bar Mount,Anti-Sway Bar Arms,Anti-Sway Bar Links) Black
Team DC Axial Yeti Chassis Protector for Yeti Matt Black
Integy Billet Machined Front Bulkhead (Black)
Integy Billet Machined Spur Gear Cover Assembly*(Silver)
Integy Billet Machined Gearbox Case Set*(Silver)
Integy Billet Machined Alloy+CF Rear Cage Stiffener (Black)
Integy Billet Machined Spring Loaded Front Bumper Mount Kit (Black)
Integy Billet Machined Upper Deck Brace*(Black)
Integy Billet Machined Front Bumper Set w/ LED Lights*(Black)
Incision Spool/Locker
Robinson Racing Extra Hard Steel One Piece 15 Tooth Idler Gear Gun Metal For Axial Yeti #1515
Parts that arrived and are ready for installation & spare parts:
Baja Bug Body
Few more parts are still on it's way:
Team KNK Stainless Hardware KIT for Yeti
CREEPERBOB custom fabricated titanium rear axle shafts for Currie centered pumpkin axle
Strong Arms RC modified RPM A Arms
Underdriven heavy duty bevel gears for front and rear
So here it goes...
Here goes the Voodoos U4 with Deuce's Wilds inside - feels like completely different car on the road
Much better handling, not too prone to rollovers in highspeed turns. Nice!
Yep, I lost right swaybar plastic piece right during my first ride :-D Waiting for replacement. New MIP C-Drive looks very solid! I was able to install it only this way - was not able to slide other end on transmission output shaft - very tight fit - I hope this way everything will be OK...
Pure beauty
Will update next week once second gift-box arrives and I put someting into my Yeti. Hope I will not destroy it (as usual) during weekend :-D
RTR = Ready To Replace, hahaha :twisted:
SLW Hub Screw Kit
Mamba Monster X
Baja Bug Body
So here it goes...
Pure beauty
