Yoda's RR10 Bomber Build... B1B IFS!
84yoda
Roseville, Ca
New lights, rc4wd squadron light pods up front and gear head 4" koh light bar in rear.
Fully extended.
Fully compressed, you can see no way near bottoming out the shock.
And upper links hitting the sway bar rod.
The fix, longer rod ends.
You can see the difference it made, I will run some rubber bump stops and will just barely clear sway bar rod and also fully compress. Im going to keep the limit straps in same place and it will limit fully extension but as it sits with trailing arms, it still has more travel then front.
RC4WD metal hi lift. Best part is it actually works."thumbsup"
Carter fab hood and inner fenders (not in picture).
Looks good!! I like how "clean" looking the SSD axles are!
I'm gonna have to try to add the window nets on my BGR chassis.
Thanks and ya the SSD housings are works of art. Just wait till you see who's panels showed up today.:mrgreen:
Damn! I already know! :mrgreen: I'm going to have a lot of catching up to do but good news is... Mine is due to arrive tomorrow! Keep the pics coming!
