Josh's Bully 2
josh6575
Way out there!
Ok here we go building another bully. Got some shiny new axles, knuckle weights, and a Rowdy racing battery tray. The outer weights are the add ons from Dlux. Drilled and tapped the Rc4wd weights so I could bolt the circular ones on. Thanks for the weights and tray Chris.
Thanks for the hospitality. I am loving these things. Its nice only wanting to change a few things on bully's instead of recreating them from the ground up.
Mounted up a Jr servo it is the MPH83T. Also going to install some 30T torque master pro motors from Holmes Hobbies. I don't know it the servo arm is going to make it to the party. I think it is going to be too long for the short arms on the knuckles.
I'll give it a try. If I have to turn down my epa its coming off. I set my steering up so I am using full throw.
Just a slight bend on each end wahoo! Chris I caught your note on the servo getting moved over by the upgraded mount. I was going to try and work around it, but an extra 1/8" of room cannot be ignored.
Made a CF .125" for Chris or 3.17mm servo plate and spaced it up with two aluminum traxxas ball ends. Lots of room for shocks and links now! I wish the servo wire was out the other side. Might have to take it apart and fix that.
I received a short robitronics servo arm from TCS crawlers. I am able to get full steer with the innermost hole. I am really happy with this. I might be raising the servo up a little. It hangs down below the axle tube. I like the lowered CG. I don't like the vulnerability. I also love the ground clearance of these axles and want to take advantage of it.
