BC-Brian
Lattice Innovations is pleased to introduce Shift Hubs.
Shifts are new hubs designed to be flexible, allowing you to adjust your offset simply by adding or removing spacers.
The core is made of machined 6262 aluminum (here in the USA).
The spacers are made of plastic offering a balance of strength and weight. The regular shift hub has an offset of .400" and weighs in at only 4 grams. These hubs run directly off the pin, allowing you to remove your hexes and save even more weight and quite a bit of that nasty wheel slop.
The hubs have 6 holes tapped to M3x0.5 and 6 other holes drilled to 3/3nd, ready for a #4-40 tap if you like.
You may need to purchase longer screws than the ones you are using in your current hubs depending on the number of spacers used.
Shifts are compatible with ANY SLW style wheel / any other wheels with the same bolt pattern.
UPDATE!!! 4.21.15 Shift hubs will now be shipping tapped for M3x0.5 screws standard (6x holes tapped to M3). There will be 6x additional holes drilled to 3/32 for a #4-40 screw, or to be used as backup M3 holes if your original ones get stripped.
We are now offering shifts in custom Anodized colors. There are currently 8 colors to choose from and we will be adding more to the lineup soon.
Get your silver shift hubs from TCS Crawlers for $40
For custom anodized colors send me a PM
Weight
Widths
Silver
Weight
Widths
Silver
