Presenting Shifts, Lightweight n' Flexible Offset Hubs
Got my set of Shifts on Saturday. Started messing around with them last night. So far I'm liking them. I was setting them up with some VP SLW v1 wheels. Using the Shifts instead of the SLW hubs. Everything installed nice and smooth. The spacers are just the right diameter that they don't stick out between the spokes. Unlike my homemade spacers.
Though I will admit I will not be using the Shifts with these wheels rather I will be using these to build some dually wheels for a build later this spring. They fit great but the pin mount functionality will serve me better in my next project.
Damn, talk about fast service!! I sent payment for a few sets of these on Wednesday evening and they were in my mailbox on Saturday. Nice work BC-Brian! "thumbsup"
As long as they are no larger in OD than the flange on the SLW hub, then they should work just fine..."thumbsup"
Well, it looks like I was only partially correct with this statement. It didn't occur to me that the largest OD on these will be closer to the hex pin than a regular SLW. That being said, it looks like these will only work with the outer (tapped) Nordic/RCBros weight. The non-tapped weights are too small in diameter for this hub to clear.
Jeremy,
Do you have any of the weights I sell yet? They may or may not clear still just curious as mine are slightly different. I was planning on getting these once he has something the will be close to a 225 hub
I have both of the NCD weight systems (Tomi) made and the new RCBro ones...what measurements you guys need?
Also Curious,
Jeremy, can you get a picture. I didn't have a set of these wheel weights to design around, but If there are changes I can make to improve the design for the next batch I would certainly do so.
Also Curious,
Sure, I will snap one this evening.
I think just making the OD slightly smaller would do the trick..."thumbsup"
Cool, keep me posted. Getting the OD slightly smaller may be challenging since I cannot adjust the bolt pattern, but lets see what we can do.
bquin said:
money sent for a set...
Thanks bquin, got it. Will get them shipped for ya.
got mine today top notch product shipping was fast and great communication, I will be buying more!!!
Got mine today, look pretty good. I will get them mounted up on the wraith and the twin hammers for this weekends trail runs.
Sent from my iPhone using misspellings due to fat fingers
Brian,
this isn't the best picture, but you can see here how the outer (tapped) weights have a slightly larger OD than the inner (untapped) weights:
These are the original NCD weights, and it sounds like RCBros is making them a bit different these days, so your hubs might work with his...
Looks good! Damn Chuck, that's a fancy ruler! "thumbsup"
Will is sending me some of his half rings to test them out with these hubs as well...
Let me know how it works out for ya. Waiting to see the fit to pull the trigger on these hubs as well as the RCBros brass rings.;-)"thumbsup"
No problem Bryce.
And to show everyone else, these hubs will work just fine with the RCBros weights:
Thanks again Will for sending me these to verify that they fit the hubs! "thumbsup"
