Scale Tire Size Charts...
This is great information... BUT... any way to organize it better? Perhaps by size in each tire class? Smallest to largest OR by brand in alphabetical order based on tire name?
Now that Scale rules tire sizes have been listed, an updated list here would be awesome!
x2"thumbsup"
Yeah, no problem."thumbsup"
Do you have any tires you want to add to the list?
Also, I couldn't find the manufactures size statements for the below, have any info?
2.2 Mashers...
http://prolineracing.com/tires/masher-2000-2.2-all-terrain-truck-tires/
2.2 Flat Irons...
http://prolineracing.com/scale/flat-iron-2.2-m3-soft-rock-terrain-truck-tires-w/memory-foam/
2.2 Mashers...
SPECS:
Inner bead diameter: 56mm (2.2")
Total outer diameter: 124mm (4.9")
Inner bead width: 50mm (2")
Total outer width: 62mm (2.4")
SPECS:
Width: 2.4" (62mm)
Inner Diameter: 2.3" (60mm)
Diameter: 4.5" (115mm)
cool list, thx "thumbsup" ....so is that all the scale tires and only made by those two companies....i thought there were more companies makin scale tires........bob
Thanks!
I will be updating the list this week, stay tuned.:mrgreen:"thumbsup"
There was a thread with a discussion on the 2.2 Proline Flat Irons, so I asked if someone could grab some measurements, and someone kindly replied
Sure man what measurements are you lookin for total height? width?
Height= 4.84 inches
Width=2.14 inches
Man am I glad I found this thread again. thanks again for all the work on this. Now I know what tires I need for the class I"thumbsup"
Need to update this thread with the new micky thompson 1.9 from rc4wd and the new proline super swapmers
RC4WD mickey thompson=
Product Specifications:
Outer Diameter: 4.75" (120mm)
Width: 1.75" (44.5mm)
Inner Diameter: 1.9" (48mm)
Advanced X3 Soft & Sticky Compound
Reinforced sidewall
Proline super swampers=
the 1.9s
SPECS:
Height:​
4.30" (109mm)​
Width:​
1.50" (38mm​
the 2.2s
SPECS:
Height:​
5.40" (137mm)​
Width:​
2.05" (52mm)​
I don't see any Imex tires
Swamp Dawgs
Size: 4"OD X 2.5"W X 2.2"ID
All-T
Size: 5.3"OD X 2.8"W X 2.2"ID
Claw dawg
G-Hawg
Size: 4.5"OD X 2.2W X 2.2"ID
